Need more power 2002 Tacoma 4x4
Discussion in '1st Gen. Tacomas (1995-2004)' started by alexdavid4, May 30, 2012.
  1. May 30, 2012 at 10:25 AM
    alexdavid4
    alexdavid4 [OP] Member
    alex
    STL
    02 tacoma 4x4 TRD
    I am new to the Tacoma world, Just bought a super clean 2002 4x4 and realized while I love everything about it... it doesn't have enough power to get out of its own way!! Im open to ideas... I have done performance chips exhaust and intake with some success on other vehicles just wondering what you think.
    Thanks
  2. May 30, 2012 at 10:28 AM
    Ripcord
    Ripcord KM6PIM
    Jim
    Northglenn, Colorado
    Spruce Mica 2013 TRD-OR
    supercharger. Chips do nothing and intake/exhaust is minimal gains if any.
    BTW its 3.4, not 4.0 as your sig says.
    Memeplayer1 likes this.
  3. May 30, 2012 at 10:30 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    make sure its running properly before you go upgrading the 3.4 really isnt that slow
  4. May 30, 2012 at 10:33 AM
    alexdavid4
    alex
    STL
    02 tacoma 4x4 TRD
    I replaced plugs wires etc. Runs smooth just not much power on the highway
  5. May 30, 2012 at 10:40 AM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    well I don't know how fast you want to go but i have no trouble getting mine to 90 on the Eisenhower.
    s92dvr likes this.
  6. May 30, 2012 at 10:45 AM
    Madjik_Man
    Colorado Front Range
    I can be in 4th gear accelerating up 12,000 passes doing 80 mph.
    How much more power do you need? And if you feel that's lacking, then you should have bought something with a V8 or turbo-diesel in it.
    :notsure:
    Xbeaus likes this.
  7. May 30, 2012 at 10:46 AM
    alexdavid4
    alex
    STL
    02 tacoma 4x4 TRD
    I plan to let my employees use the truck so I don't want to take away from the reliability... small upgrades are more feasible.
  8. May 30, 2012 at 10:48 AM
    alexdavid4
    alex
    STL
    02 tacoma 4x4 TRD
    If there's nothing out there its ok.. I just wanted to check with you before i waisted money on eBay parts
  9. May 30, 2012 at 10:51 AM
    alexdavid4
    alex
    STL
    02 tacoma 4x4 TRD
    I like the truck.. Just wanting a bit more out of it. Thanks
  10. May 30, 2012 at 10:53 AM
    ktmrider
    Junk
    supercharger and some injectors is the only reasonable option in your situation
  11. May 30, 2012 at 10:53 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Supercharger + URD 7th injector
    /thread
    Anything else is just a waste of time, money, and effort.
  12. May 30, 2012 at 10:53 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    Tell us more about your truck. Engine size, tire size, diff. ratios. Automatic or stick. There are things you can do but they will cost money.
  13. May 30, 2012 at 10:56 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    2002 TRD 4x4 means he's got a 3.4L and 4.10 gears
    erice likes this.
  14. May 30, 2012 at 11:24 AM
    alexdavid4
    alex
    STL
    02 tacoma 4x4 TRD
    3.4 4 door auto
  15. May 30, 2012 at 11:26 AM
    alexdavid4
    alex
    STL
    02 tacoma 4x4 TRD
    We put the largest tires with out lift... Ill have to grab the size when I get home
  16. May 30, 2012 at 1:57 PM
    trmarshall1
    trmarshall1 The Least Interesting Man In The World
    Tim
    San Jose, CA
    02 Tacoma 4x4 TRD Supercharged
    4" Pro-Comp Lift, TRD cat back exhaust, grey wire mod, clutch pedal linear spring mod
    The 3.4, even stock has a fair hp:weight ratio but by no means is it going to be sports car fast. I have the supercharger and it pulls hard in low gears and has no problem hitting 100. Could go faster, but why would I need to? I need to get the URD 7th investor kit to get the most out of it though. There are a couple superchargers for sale in the 1st generation marketplace, 2k and 1.5k iirc, not cheap, but worth it and performance always comes with a price. You really have to ask yourself what it is the truck will be used for and do you really need the extra power. Good luck man. Btw, the charger requires you run 91 octane...more money right there.
  17. May 30, 2012 at 7:31 PM
    scyota03
    scyota03 Well-Known Member
    sumter,southcarolina
    03 trd prerunner
    3 inch coil spiring spacer, front bull bar
    some bigger cams could get u a lil more power to
  18. May 30, 2012 at 7:34 PM
    sportsterchop200
    sportsterchop200 Well-Known Member
    NE Georgia
    03 TRD Tacoma 4x4
    OME 881, Bilstein 5100 @ 0", OME 10mm JK spacer, Stock rear on 265/70-16
    If you want the max power go with the super charger or a turbo. For cheap mods go with the deck plate mod or a variation of it, a straight through muffler and a tune up with everything lubed. I have heard people claim success with long tube headers also. If you can reduce weight that may help also.
  19. May 30, 2012 at 7:42 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    :rofl:
    There is absolutely no point in replacing a cam unless you get a full cam kit, upgrade fuel, and air delivery. At which point you'd be well beyond the cost of a supercharger.
    More importantly, is there even an aftermarket cam available for the 5vz. :notsure:
    I've seen them for the 2RZ/3RZ only.
  20. May 30, 2012 at 8:38 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
