Need more stopping power!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mr.Jack, Jun 14, 2013.
  1. Jun 14, 2013 at 8:09 PM
    Mr.Jack
    Mr.Jack [OP] Active Member
    Wilmington, NC
    The Black Pearl
    Remote Start, 4 Hella Lights, Brush Guard, Grey Wire
    I've never been in an accident and I consider myself a good driver. Going with the flow of traffic, I can scan far enough ahead and plan accordingly. In normal traffic, my brakes are sufficient, however, some jackass ran a stop sign today and I mashed my brakes pretty hard. Avoided an accident, but I feel like the brakes should have performed better. They are new pads and rotors. Any suggestions to improve stopping power that won't cost me a small fortune?
  2. Jun 14, 2013 at 8:15 PM
    Osugoose
    Osugoose Well-Known Member
    Sean
    Tulsa, OK
    2011 Sport DCLB 4x4
    885x w/ nitro sports,Dakars w/ 182,Katskinz two tone leather
    Ceramic Pads??
  3. Jun 14, 2013 at 8:15 PM
    Moco
    Moco Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    Are they OEM or autoparts store brand?
    You can try switching to performance pads/rotors from manufacturers like Hawk or EBC, but you take the risk of greater noise and shorter life.
    At the end of the day you got to realize a Tacoma is not a Corvette. Short of outfitting a new brake system, you will always take longer to stop in your heavier taller truck than a lighter, shorter car.
  4. Jun 14, 2013 at 8:21 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Add stainless steel brake lines. That will take out the expansion on the rubber lines and increase pressure in the cyclinders.
  5. Jun 14, 2013 at 8:28 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    It's important to note none of these mods improve stopping distance. They simply make the brakes "bite" earlier and can improve pedal feel. The stock brakes are already powerful enough to lock up the tires if ABS weren't present.
  6. Jun 14, 2013 at 8:28 PM
    Mr.Jack
    Wilmington, NC
    The Black Pearl
    Don't know what's on it. The dealer replaced everything for me. Do performance pads make much difference?
  7. Jun 14, 2013 at 8:32 PM
    KenLyns
    Belly of the Beast
    Brake pads are a compromise among bite, squealing noise level, and dusting. OE pads tend to be quiet and generate little dust, at the expense of initial bite. Dealer would use OE pads.
  8. Jun 14, 2013 at 8:53 PM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Convection Oven, Az
    06 DCSB, 06 LC120
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, Spidertrax wheel spacers, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s
    you could try the tundra upgrade. I don't know too much about it but my Chipskip did this on his 1st gen and said the difference was "night and day". Its basiclly a big brake upgrade for the 1st gens
  9. Jun 14, 2013 at 9:24 PM
    tacomataco2
    tacomataco2 Well-Known Member
    Eastham Mass
    02 Dbl cab Silver
    Bilstein 5100's, eibach coils, u bolt flip, Dakars/d6xl, Ome shackles, Poly sway bar bush, Poly rack bush, voltmeter, led guage lights, magnaflow stainless catback, stainless cats, deckplate mod, afe filter, tundra brakes,PIAA fogs behind grillecraft, color matched grille, soft topper, Projector retrofit, Allpro bumper , Blitzpro light bars, Alpine/ rock fosgate sound system, 35% tint, Some derped stuff
  10. Jun 14, 2013 at 9:31 PM
    taco terror
    taco terror My ECT button stays clicked ;)
    Austen
    North Carolina
    Non-Turd Gen
    AR Baja wheels, 33 BFG ATs, 4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, Line-x
    I feel the same. When in my parents vehicles ('11 Sonata, '12 Ram) you have to feather the brake pedal versus my trucks. Their brake pedals take a whole lot less travel than mine does, I have to go a ways in mine.
  11. Jun 14, 2013 at 9:36 PM
    Guerrilla
    Guerrilla L(.)(.)K@B(.)(.)Bz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    If you don't mind saying, what did the Tundra upgrade run you? And considering that, was it worth it IYO?
  12. Jun 14, 2013 at 9:55 PM
    davidpick
    davidpick NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    i have the tundra brake upgrade and love it. fitted the larger 231mm calipers, rotors and stainless lines for ~$400. huge upgrade in brake performance. make sure your wheels will work with the calipers, obviously. The OEM "star" 16" alloys on 2001-2004 Tacomas WILL clear the 231mm calipers.
  13. Jun 14, 2013 at 10:04 PM
    tacomataco2
    Eastham Mass
    02 Dbl cab Silver
    I got Ebc blank rotors and pads, and remaned calipers, also different brake lines, so i think it cost about $500. and it was totally worth it!:D These brakes are nasty. If there was an easy way to swap a toyota disc setup on the rear i'd probably do that too..
  14. Jun 14, 2013 at 10:31 PM
    Guerrilla
    D. Cooley
    Coast to Coast
    Stuff
    That's not too bad of a price, if it's as good as you guys say it is. Having better brakes is def a good thing.. I really wish these trucks came with rear disc. There's bound to have been somebody on here that has put rear disc on, I'd be interested in that myself.
  15. Jun 15, 2013 at 5:20 AM
    Swimmerboy2112
    Swimmerboy2112 Well-Known Member
    Brian
    Walnutport, PA
    02 TRD V6 5 Speed X-Cab
    Borla exhaust, K&N intake, ARB bumper, 16x8 Konig Countersteer Offroad wheels, 20% Tint
    I have EBC drilled rotors and green stuff pads, stops pretty well but it's no sports car.
  16. Jun 15, 2013 at 9:53 AM
    tacomataco2
    Eastham Mass
    02 Dbl cab Silver
    I've only seen kits that use gm calipers, and there's no e brake :(
  17. Jun 15, 2013 at 10:38 AM
    Guerrilla
    D. Cooley
    Coast to Coast
    Stuff
    Eeh wouldn't like that, e brake comes in handy.
  18. Jun 15, 2013 at 3:09 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Colorado
    98 3.4L V6 TRD Ext. Cab 4x4 SR5
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    x2 on the Tundra front brake updgrade. That's what is on mine.
  19. Jun 15, 2013 at 4:21 PM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    Brembo rotors, hawk hps pads, and stainless lines stops on a dime. I have no complaints.
  20. Jun 15, 2013 at 5:27 PM
    Guerrilla
    D. Cooley
    Coast to Coast
    Stuff
    What did that run you, if you don't mind?
