Need New Rear Shocks....14"-25"????????
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfgang123, Jul 10, 2010.
  1. Jul 10, 2010 at 10:38 PM
    wolfgang123
    wolfgang123 [OP] Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    i need some new rear shocks that collapse to 14ish" and extend to 25ish" i cant seem to find any. i was going to go with 5125 but they collapse to 15ish" and i dont really want to loose any uptravel...any help guys??
  2. Jul 10, 2010 at 10:43 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
  3. Jul 10, 2010 at 10:51 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    Bilstein 7100 10" short body shock... 255/70 valving... 14" collapsed, 24" extended...
    Part number AK7110SB
    Hit up Sonny at Downsouth Motorsports for pricing...
    Also order the bushings from the 5125s and use them in place of the heim mounts that come with the shocks...
  4. Jul 10, 2010 at 10:55 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    someone get this shock genius a beer as a thanks for the info that spews from him.
  5. Jul 10, 2010 at 10:56 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    dont thank me yet...
    7100s are not as cheap as 5125s... hahahahah
    but, i am running 7100s on my truck and they have been great so far... they don't heat up since they have reservoirs...
    :D
  6. Jul 10, 2010 at 11:23 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    thanks mike but at $180 a shock HOLY SHIT!!!! i dont have a truck like yours...although i wish i did
  7. Jul 10, 2010 at 11:28 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    told you... hahahah
    ok, here is one solution...
    Bilstein 5125... 9" travel... 15" collapsed, 24" extended....
    limit your up travel 1" with an added bump...
    BE5-A463-H5
  8. Jul 10, 2010 at 11:54 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    BE5-6248-H5
    or BE5-A464-H6
    i cant decide on vavling?
  9. Jul 11, 2010 at 12:04 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    255/70 is pretty standard... 170/60 will be a bit soft and is more for dual shock set up...
  10. Jul 11, 2010 at 12:09 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Mike, been seeing and hearing about a lot of failures of 51xx billies at the seal with hard use. The failures have occurred on relatively (a couple of wheelin seasons) new setups. Saw two BE5-6249 H5s today (on the same truck) that were leaking. Fitment doesn't appear to be the issue.
    Any ideas about what is happening? Are these model shocks just too "light duty" for 3500-4000 lbs rigs that spend a lot of time on the trail?
  11. Jul 11, 2010 at 12:16 AM
    th3bigk0
    th3bigk0 GETTN IT
    Dylan
    Lamecaster
    13 TRD Double Cab
    Fox 2.5 RR C/O's,Camburg UCA,Camburg Spindles,KING 2.5,OME Dakar Leafs,285 KM2,XD HOSS 16'',BHLM,HID's,CB,Hornblasters Shocker 540 train horn,KICKER 12 ported....
  12. Jul 11, 2010 at 5:40 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Im running the 7100 with resi 10" short bodies, valving is 170/60 Its pretty Soft and to me It feels perfect for how light the rear is. But if you do a cage and have more weight I'd go with 255/70
  13. Jul 11, 2010 at 8:27 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    ya know, a couple of us were jumping our trucks with 5125s and never had leaks...
    it could be a bad batch of seals?
  14. Jul 11, 2010 at 8:40 AM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    I run 7100 10" shoortbody w/ Resi's and love them as well.
    They generally can be found used for about 200.00 and are easy/cheap to rebuild. Thats what I did.
  15. Jul 11, 2010 at 12:54 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    mkay so i was thinking the 10.17 5125 and 2 inch shackles?? yes??
  16. Jul 11, 2010 at 1:21 PM
    th3bigk0
    th3bigk0 GETTN IT
    Dylan
    Lamecaster
    13 TRD Double Cab
    I'm running the 9.24s with Downey leafs and 2"shackles,I want more up travel.but I needed to extend my bumps so I didn't bottom out the shock
  17. Jul 11, 2010 at 4:08 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    ok i will wait till i finish building my shackles before i buy shocks and i will take some more measurement then...thanks fellas!
  18. Jul 11, 2010 at 6:42 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks for the feedback. Not trying to ruffle feathers, just curious if others had seen this. I doubt that the Tacoma that had these has been used for anything except our tight, twisty, muddy, slow speed northwest trails.
  19. Jul 11, 2010 at 9:11 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    OR, maybe some mud got into the seals, dried up, and is now lodged in there?
  20. Jul 11, 2010 at 9:27 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    yea i would go with mud being the problem.. ive had that problem quite a few times..
