Need new shocks!! Can't decide!
Discussion in 'Suspension' started by rmarqu2, Mar 7, 2013.
Which should I get?
Poll closed Apr 6, 2013.
  1. ICON reservoirs
    40.0%
  2. Extended Billies + Powertrax no-slip
    60.0%
  1. Mar 7, 2013 at 8:45 AM
    rmarqu2
    rmarqu2 [OP] YES... i am a murse....
    Roger
    Baton Rouge
    09 Black 4x4
    FOX 2.5 coilovers, FOX 14" rears, AP expos, AP front plate bumper and skid, lightforce 240 blitz, warn m8000, 3/8 amsteel, BAMF sliders, cheap Chinese rock lights, ARB lockers all around
    Ok..... snapped my rear billies last weekend wheeling so gonna take this opportunity to upgrade a bit.
    Two choices are:
    1. ICON reservoirs for $480
    2. Extended billies 5100 (F4-BE5-B110-T5) for $190 and save up for a powertrax no-slip rear diff
    (Currently running a Toytech ultimate with AAL and mostly offroad rocks and hills.)
  2. Mar 7, 2013 at 9:07 AM
    rmarqu2
    Roger
    Baton Rouge
    09 Black 4x4
    Also, would my current setup in the rear allow me to take full advantage of the flex that the ICONs are capable of?
  3. Mar 7, 2013 at 9:11 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    I have the 5100s. no complaints.
  4. Mar 7, 2013 at 9:18 AM
    rmarqu2
    Roger
    Baton Rouge
    09 Black 4x4
    How much you had to tweak your bumps?
  5. Mar 7, 2013 at 9:22 AM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    What about the 5150's?
  6. Mar 7, 2013 at 9:26 AM
    rmarqu2
    Roger
    Baton Rouge
    09 Black 4x4
    I'm just going by what the toytech rep recommended: the two listed above and some OME's. never looked into the 5150s
  7. Mar 7, 2013 at 10:30 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    I think I would go billies and locker. Really, for what we do, you would never use the remote reservoirs to their full potential.
    Edit: Now that I think about it, unless the compressed length of the extended billies are shorter than the ones that were already on it, then the extended ones will break just like the other ones. The real solution to the problem is taller bumpstops or maybe even hydraulic bumpstops so that it can still get most of its flex but has something to slow it down before it snaps the shock shaft again.
  8. Mar 7, 2013 at 10:34 AM
    FALlover
    FALlover Well-Known Member
    luziana
    98 tacoma SR5, camo paint
    trail gear bumbers, warn 9000
    are the extended billies stronger than the ones you broke?
    are the icon's stronger than the billies?
    just coming at it from that angle
    my vote is billies and locker
