Need new speedometer gear
Discussion in '1st Gen. Tacomas (1995-2004)' started by smmarine, Feb 23, 2016.
  1. Feb 23, 2016 at 7:05 AM
    smmarine
    smmarine [OP] Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I changed gears in my 99 4wd, went from 4.10 to 4.56. Now my speedometer is reading faster then what I am traveling. I was doing 40mph coming back from the shop and my actual speed on a GPS was between 36-37.
    I know you can change the speedometer gears to accommodate, my question is where is that gear located and where can I go to order these gears?
  2. Feb 23, 2016 at 7:12 AM
    pofarm
    pofarm Well-Known Member
    Greg
    SW MO
    1996 Taco
    The gear is located on the passenger side of the transfer case. It's a dealer only part.
    Tinmann likes this.
  3. Feb 23, 2016 at 11:25 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
  4. Feb 24, 2016 at 8:02 AM
    smmarine
    Melbourne FL
  5. Feb 24, 2016 at 2:28 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
  6. Feb 24, 2016 at 5:35 PM
    smmarine
    Melbourne FL
    I pulled my speedo gear. Showed 32:11. Went to Toyota and ordered a 33:11.
    Read somewhere 1 tooth adds about 5%. My speedo is 6% off, so a 33 with be real close. I'm plan to go a tad bigger tire soon, so should be dead on then.
    boostedka likes this.
  7. Feb 24, 2016 at 9:53 PM
    nzbrock
    Noah
    San Marcos, TX
    No it's not. Many of those parts are interchangeable. You just need to match the transmission/transfercase. I got a different gear for my 2wd transmission from that list when I went from 31s to 255/85s. It put my speedometer exactly where it should be.
  8. Feb 25, 2016 at 4:22 PM
    smmarine
    Melbourne FL
    Well, the 33:11 gear made it a little better, but the speedometer is still fast. At 55 I'm actually doing 52.
    Eventually I'll increase my tire size so that will help
  9. Feb 25, 2016 at 4:29 PM
    boostedka
    James
    NM
    What was the % of increase in your speedo going up 1 tooth?
  10. Feb 26, 2016 at 12:30 AM
    smmarine
    Melbourne FL
    Only a couple percent
  11. Feb 26, 2016 at 12:44 AM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    I may try and sway gears out on mine, just went up to 4.88s and it's off quite a bit.
