Need new suspension?!
Discussion in 'Suspension' started by Mike_0816, May 31, 2023.
  1. May 31, 2023 at 7:12 AM
    Mike_0816
    Mike_0816 [OP] Active Member
    Mississippi
    2015 Gray Tacoma TRD
    R/C 3.5" lift, 285/75/16 Toyo M/T's
    Hey guys, new here. So I made a mistake and aloud a shade tree shop sell me the Rough Country 3.5 lift kit for my 2015 Taco. I’ve got 285/75/16 Toyo M/Ts. It ride terrible. I need advice on what to replace it with. I was thinking King front coil overs or do I need to replace everything, front and rear? Looking for a silky smooth ride.
  2. May 31, 2023 at 3:44 PM
    eurowner
    eurowner Duke Sky
    Scoty
    MT tires will always ride harshly. 285-75-16 are E rated, aka 10 ply which rides harsh. What tire pressure?
  3. May 31, 2023 at 3:49 PM
    Clearwater Bill
    Billy
    Largo Florida
    This. ^^^ Start easy. To maybe get better.
    Side note. Unless a truck is a purpose built street queen with high $ bits, it won't ride 'silky'.
    Some will ride better than others, but when a vehicle is built to carry loads, empty will be un-silky.
  4. Jun 1, 2023 at 1:25 PM
    Mike_0816
    Mississippi
    It’s my daily but, also what I use to get to around my land when I need 4x4. Just wondered if I replace the suspension with something like King, would it help?
  5. Jun 1, 2023 at 1:25 PM
    Mike_0816
    Mississippi
    35 psi.
  6. Jun 1, 2023 at 1:47 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    King is big money for your needs. 5100s or run what you got. Stock off-road suspension is probably the softest ride out there.
    I’d start by throwing 3-400 lbs in the bed and go for a ride.
  7. Jun 1, 2023 at 6:21 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Drop it to 32 or 30psi and how does that feel?
    batacoma likes this.
  8. Jun 5, 2023 at 8:33 PM
    05 4x4
    05 4x4 Well-Known Member
    I just went with the kings and it definitely isnt plush... So that wont get to where your wanting to go unless you go with accutune and ask them to tune them to be on the plush side.
  9. Jun 11, 2023 at 12:00 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    are you running e rated tires? if so, doesn't matter what you have, kings, Bilstein, fox, rough country......they will all feel rough.
    are you running wheel spacers? i noticed when i ran spacers, the ride got rougher.
    it isnt like kings or fox are plush. they are firm as well, but they absorb bumps much better then stock.
  10. Jun 11, 2023 at 12:25 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Do you know the spring rate on the RC coils?
