Need New Switches
Discussion in 'OTRATTW' started by Arrowshot, Apr 8, 2020.
  1. Apr 8, 2020 at 11:19 AM
    Arrowshot
    Arrowshot [OP] Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Sir/Maam,
    I need to change out the rocker switches I currently have on the left side of my steering wheel and convert them to push switches to fit the OEM slots above the center console and below the media center. Want to have Green/Green with one labeled Apocalypse Lights and one labeled Light Bar. Sending pictures of existing switches and would like to have same 5 pin set up on the push switches so I don't have to do much re-wiring. Also if there is a possibility of overnighting let me know the shipping options. Would appreciate a call if you can do so and you can reach me at 256-468-1744 and you can also communicate less directly with me at hunting1archery@comcast.net.
    Sincerely,
    John Evans
  2. Apr 8, 2020 at 11:36 AM
    2BeersPlease
    2BeersPlease Well-Known Member
  3. Apr 8, 2020 at 12:51 PM
    Arrowshot
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Give me a call if you don't mind (256-876-9599). I am willing to compromise if you have something that works. Took a look at the link and issue I always run into is their quote "without any modification to the original dash." Never can tell which part of dash they are talking about or the quote "Supplied with harness and connector." 3 pin, 4 pin or what? Makes buying switches a real pain to figure out.
