Need new tires, what will fit?
Discussion in 'Wheels & Tires' started by c0b2a, Nov 2, 2009.
  1. Nov 2, 2009 at 3:26 PM
    c0b2a
    c0b2a [OP] Well-Known Member
    I have read through a bunch of threads on what tire will fit what but with lots of conflicting information.
    I just got some money from backpay. I not quite enough to pay for a lift and tires, but I need new tires asap. I want to fit the largest bfg A/T I can without having to lift or cut or worry about crazy rubbing. What can I go with?
    Thanks a lot for the help on this, I admit I am new to all this.
  2. Nov 2, 2009 at 3:26 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    265/75/16 should be what youre looking for
  3. Nov 2, 2009 at 3:40 PM
    c0b2a
    That is the standard size the TRD's come with correct? Can I not go up in size at all without having to worry about all the "side effects"?
  4. Nov 2, 2009 at 3:42 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    they shouldve come with 265/70/16 if you have the 16" wheels
    265/75 is the same width just a bit taller
    i think on the new ones you have to start lifting or cutting to fit any larger
  5. Nov 2, 2009 at 3:43 PM
    c0b2a
    I see, thanks for the info.
  6. Nov 2, 2009 at 4:46 PM
    Jon4x4
    Jon4x4 Well-Known Member
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    johnw on here is running 285/70/17's i think on his stock Prerunner. He doesn't rub unless really sharp turns
  7. Nov 3, 2009 at 6:18 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    yah i got 285/70/17 stock trd sport prerunner 1/4inch wheel spacer and removed mud flaps rubs UCA at full turn. also had to trim minimal plastic where mud flap was
