Need new trans mount?
Discussion in '1st Gen. Tacomas (1995-2004)' started by PrerunnerVsix, Oct 1, 2015.
  1. Oct 1, 2015 at 4:28 PM
    PrerunnerVsix
    PrerunnerVsix [OP] Well-Known Member
    Ali
    Houston, Tx
    2013 Tacoma TRD Sport
    When I come to a mildly hard stop I can feel a small thud. I was thinking it was just axle wrap but after taking a look I found my trans moving a little and some play in the drive shaft. Here are videos of both , can you tell me if this is normal or do I need to replace? I believe the center support bearing is shot but Im unsure of the trans mount. Thank you
    https://vimeo.com/141123849https://vimeo.com/141119663
  2. Oct 1, 2015 at 5:22 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    that carrier bearing play isn't normal. need a new one soon. video of tranny play isn't "available yet".
  3. Oct 1, 2015 at 5:30 PM
    PrerunnerVsix
    Ali
    Houston, Tx
  4. Oct 1, 2015 at 5:48 PM
    deckeda
    deckeda Well-Known Member
    '04 Double Cab PreRunner SR5
    "When I come to a mildly hard stop I can feel a small thud."
    This is exactly me as well. I'm guessing both trans mount and carrier bearing are issues for your truck and probably mine too. Didn't I see a thread here about the bearing? Off to go look ...
    Edit: Why yes, here: https://www.tacomaworld.com/threads/how-to-replacing-carrier-bearing.260283/
    That thread says about 1/8" of play is normal?
  5. Oct 1, 2015 at 6:05 PM
    PrerunnerVsix
    Ali
    Houston, Tx
  6. Oct 1, 2015 at 6:06 PM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    I would replace both & U-joints are usually due about the same time carrier bearings are in my experience.
    I just put a new tranny mount in my 91 toy very similar style and it doesn't have any play like that.
    Got mine on parts geek. Anchor brand seems well build and fit well.
  7. Oct 1, 2015 at 6:08 PM
    CodeSeven
    Serge.
    Coachella Valley
    yeah that kind of play is bad as well. change both mounts a.s.a.p
  8. Oct 3, 2015 at 8:54 AM
    PrerunnerVsix
    Ali
    Houston, Tx
    After market mounts ok? Or better go oem?
  9. Oct 3, 2015 at 9:01 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    By the looks of the mount, you are 2wd, correct?
    If so, I'd go with OEM.
    If you're 4wd, do this mod and it will cure the problem.
  10. Oct 3, 2015 at 9:03 AM
    PrerunnerVsix
    Ali
    Houston, Tx
    Yes 2wd, what is the mod on the 4wd mount? Is it tge bolt going through the rubber?
  11. Oct 3, 2015 at 5:17 PM
    CodeSeven
    Serge.
    Coachella Valley
    i personally have faith in after market parts. rarely have problems if any, and they're usually found before installation or even the final sale.
    Fallguy6666 likes this.
  12. Oct 3, 2015 at 10:12 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    On the fence a little with trans mount, the rubber looks good & intact but the bolt movement concerns me, depends if the bolt is molded/grommetted into the mount itself...
    As far as the carrier goes , Toyota has no real specs for operation parameters, it is assumed that as long as the rubber isn't torn/ the bearing isn't squealing or froze up, it's good, not unusual to see up to 7/16" play in 2 piece shaft...
  13. Oct 4, 2015 at 5:10 AM
    Ritchie
    Here is the link to what Marlin does:
    http://board.marlincrawler.com/index.php?topic=95884
    Only thing I did was incorporate his idea into my 4wd trans mount.
    Works like a charm.
    Good luck.
  14. Oct 4, 2015 at 7:41 AM
    PrerunnerVsix
    Ali
    Houston, Tx
    I think ill replace the carrier first and see if the thud goes away, if not ill do the mount next.
  15. Oct 4, 2015 at 11:11 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    You sure it's not axle wrap ?? That "thud" you mention is text book condition & if your leafs are stock I'm betting it is axle wrap...
  16. Oct 4, 2015 at 12:02 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    My sons transmission mount bolt is just finger tight. When I found it it was completely loose. I cold just push it up and out. I looked and looked at it but I have no idea what it's purpose is. I am fosure going to do the motor mount bolt mod on both our trucks.
    If anyone can explain what that bolt does I am all eyes. Cant say ears cause I am technicall reading this.
  17. Oct 4, 2015 at 1:23 PM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    So what is the effect of this mod? I have a stubborn drive train vibration even after replacing u-joints, carrier bearing, and having the drive shaft balanced. Is this a cure for that?
  18. Oct 4, 2015 at 1:32 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    If lifted, drop the carrier 3/4".. might be a wheel bearing even
  19. Oct 4, 2015 at 3:02 PM
    PrerunnerVsix
    Ali
    Houston, Tx
    Might be, how can I make sure?
  20. Oct 4, 2015 at 4:28 PM
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    You could purchase a couple of cheap u bolts and clamp them to the springs forward the axle. If the clunk goes away it's springs. Search "Goodbye axle wrap mod". This mod is only temporary, the springs continue to weaken over time.
