Need new transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Aust1n11, Feb 27, 2023.
  1. Mar 1, 2023 at 6:30 AM
    #41
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    :facepalm::annoyed::censored:
    auskip07 and RustyGreen like this.
  2. Mar 1, 2023 at 6:40 AM
    #42
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    Try moving the transmission lever to the left after you put it in drive. That will put it in S4 mode which will lockout 5th and 6th gear. If it doesnt do it then, its likely torque converter lock-up.
    908tacoma and SR-71A like this.
  3. Mar 1, 2023 at 6:44 AM
    #43
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    You show me the guy who says "I changed my fluid regularly and it caused the transmission to fail".
  4. Mar 1, 2023 at 6:46 AM
    #44
    Clearwater Bill
    Billy
    Largo Florida
    CG256, Steves104x4 and RustyGreen like this.
  5. Mar 1, 2023 at 8:21 AM
    #45
    Jyruiz
    Jyruiz Well-Known Member
    Juan
    La Mirada, CA
    2021 DCLB Off-Road 4x4
    Glad you are getting your transmission replaced, please let us know how it performs after the install.
    Steves104x4 likes this.
  6. Mar 1, 2023 at 6:27 PM
    #46
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    I've never changed transmission fluid and never had a problem. 228k and 165k were the top two.
    jaxyaks and 908tacoma like this.
  7. Mar 1, 2023 at 6:48 PM
    #47
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I'm glad it worked out for you.
  8. Mar 1, 2023 at 6:55 PM
    #48
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Abscence of evidence isn't the evidence of absence
  9. Mar 1, 2023 at 7:13 PM
    #49
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Brand new, reconditioned or salvaged?
    SR-71A likes this.
  10. Mar 1, 2023 at 7:24 PM
    #50
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    As mentioned above change out the center bearing and u joints. Tell them you’ll pay the core charge and throw the original tranny into the bed; then you’ll have one to rebuild or trade
    RustyGreen likes this.
  11. Mar 1, 2023 at 7:30 PM
    #51
    erok81
    erok81 Well-Known Member
    Imposter
    100%. I follow some dude on IG that’s exactly like the. Dealer says replace transmission. Turns out it’s a fuse. Dealer says replace entire wiring harness. Turns out it’s a relay.
    Not sure if it’s just laziness, policy, or people just can’t troubleshoot anymore.
    Shades_Of_Red and cryptolime like this.
  12. Mar 2, 2023 at 5:37 AM
    #52
    OMGitsme
    Sold
    Me too!!!
  13. Mar 2, 2023 at 5:41 AM
    #53
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    :jpow::facepalm:
  14. Mar 2, 2023 at 6:33 AM
    #54
    OMGitsme
    Sold
    :burnrubber::lalala:
  15. Mar 2, 2023 at 6:43 AM
    #55
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    I don't know if it was the cause of it, but the 2 transmissions I have had to have rebuilt just happened to be the two transmissions that I changed the fluid on...
  16. Mar 2, 2023 at 6:45 AM
    #56
    jaxyaks
    I would bet over 75% of Toyotas on the road have never had the transmission fluid changed, and probably the same number have not had the differential flit changed either..lol
    OMGitsme[QUOTED] likes this.
  17. Mar 2, 2023 at 6:50 AM
    #57
    tacotoospicy
    tacotoospicy Well-Known Member
    Luke
    P'cola, FL
    2019 TRD OR
    sirius xm
    I've heard stories of people changing there ATF and then having issues... later on obviously in the vehicles life after not touching it.
    Anyways glad OP got his new tranny replaced
  18. Mar 2, 2023 at 6:57 AM
    #58
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    that will happen if you wait until 200k to change the fluid
    RustyGreen, SR-71A and tacotoospicy like this.
  19. Mar 2, 2023 at 7:07 AM
    #59
    jaxyaks
    That was not the case on either one of them...50-60K on both, like I said it could have been a coincidence but it came to mind when I read the post about transmission fluid changes
  20. Mar 2, 2023 at 8:35 AM
    #60
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    Was that a drain and fill or a flush?
