Need new transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Aust1n11, Feb 27, 2023.
  1. Mar 2, 2023 at 8:36 AM
    #61
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    Drain, fill and filter change
    Shades_Of_Red[QUOTED] likes this.
  2. Mar 2, 2023 at 8:38 AM
    #62
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    usually people change their fluid when there's already a problem. new fluid isn't going to damage a transmission. that's like saying changing your old, dirty motor oil is bad for your engine.
    Steves104x4 likes this.
  3. Mar 2, 2023 at 9:14 AM
    #63
    DougNuts
    DougNuts Well-Known Member
    Georgetown, KY
    N/A
    The difference between motor oil and transmission fluid is that the crap in old transmission fluid is the friction material that the transmission is relying on. That's why they can slip after changing the fluid.
    My advice is worth what is paid for it, but I'm a fan of transmission drain and fills, particularly on newer vehicles with thinner fluids. I'm not sure how much is changed on a Tacoma, but most cars I’ve had will get about 1/3 of the capacity replaced by a drain and fill, and the impact on additive performance (and thereby transmission operation/protection) can be substantial. The same applies to coolant.
    Canadian Caber and RustyGreen like this.
  4. Mar 2, 2023 at 11:09 AM
    #64
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I like doing a drain & fill also, especially on an older vehicle with an unknown history. I refer to it as a "soft change".
    If you get close to 100% percent of the old fluid out you hit the (dirty) transmission with new full strength additives - like taking a laxative - everything cuts loose right now.
    With a soft change you get some fresh additives in there to start doing some gentle cleaning, more like adding some fruit to your diet instead of the laxative.
  5. Mar 2, 2023 at 11:18 AM
    #65
    DougNuts
    Georgetown, KY
    N/A
    :rofl:
    RustyGreen[QUOTED] likes this.
  6. Mar 5, 2023 at 9:34 AM
    #66
    Taco X
    Taco X Man of almost frightening genius
    James
    Midwest and Southwest
    2022 SR 4x4 V6
    lift, 255/85r16, 5.29 gears
    Some of the jokes on this forum are hilarious
  7. Mar 5, 2023 at 4:28 PM
    #67
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    To echo what others have said, Toyota does not tinker with, fix or repair the transmissions in Tacomas. There is zero service info or tech support available to Toyota technicians regarding most transmission issues.
    If it doesn’t work properly, the best you are going to get from the dealer is, “its not repairable, and you need a new one” . So yes its not repairable BY THEM, but may be worth a second opinion from a reputable transmission specialist.
    In my case the estimate to replace my “fried” transmission by the dealer was @ $9k , and a bit less for a reman. Local transmission shop had it repaired and running like a top for under $2K worth of parts and labor. Sheesh.
    Shades_Of_Red and Canadian Caber like this.
  8. Jul 12, 2025 at 6:45 PM
    #68
    zacinnc78
    zacinnc78 Well-Known Member
    Still deciding which taco to order
