Need new wires...
Discussion in '1st Gen. Tacomas (1995-2004)' started by SmokeyDP, Oct 4, 2009.
  1. Oct 4, 2009 at 5:21 PM
    SmokeyDP
    SmokeyDP [OP] Well-Known Member
    Somerville, NJ
    03 Tacoma
    My 97 V6 with 176k on it has a slight miss when it is floored above 3k rpm. I bought some new plugs to learn that the wires and plugs are still the originals. The wires were stamped 1996.
    I noticed the passenger side has 3 coil packs and each pack has a wire that goes to the drivers side. While I was pulling off the drivers side one of the metal pieces inside of the wire that clips over the end of the spark plug broke out. Should I just replace the 3 whole wires coming from the coil packs and the ends that snap onto the plugs or should I do something with the passenger side too?
  2. Oct 6, 2009 at 7:15 AM
    SmokeyDP
    Somerville, NJ
    03 Tacoma
    I was in a pinch to move the truck so I had to pick up some spark plug wires from pepboys until the OEM ones arrived. After putting in the new OEM plugs from the dealer and the pepboys prostart cables the truck runs really rough. I swapped on 2 (3rd was ripped) of the original 176k mile wires and it did run better so I am hoping it's just that the truck doesn't like the cheap wires.
  3. Nov 21, 2009 at 9:19 AM
    tmantstud
    tmantstud High Mileage Work
    Kansas City, Kansas
    98 Tacoma high mileage
    Bed liner, Polk db651s speakers, JVC head unit, Coverking custom saddle blanket seat cover
    Do you know who the manufacturer of the OEM wires is? Is it Denso?
  4. Nov 22, 2009 at 5:55 PM
    SmokeyDP
    Somerville, NJ
    03 Tacoma
  5. Nov 23, 2009 at 7:51 PM
    tmantstud
    Kansas City, Kansas
    I actually traced the denso's back to the denso part number and picked up a brand new set on Amazon for $35
