Need OEM LED bed light parts list for a 22 SR please
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lanchefan21, Feb 14, 2022.
  1. Feb 14, 2022 at 3:48 PM
    lanchefan21
    lanchefan21 [OP] Well-Known Member
    2023 Off Road DCLB 4x4, Lunar Rock
    I know it's in a thread around here but for the life of me can't find it. Want to install the OEM LED bed light in my 22 SR AC 4x4.
    Anyone have the P/Ns? LED lights, interior switch, relay etc...
    Thanks!
  2. Feb 14, 2022 at 4:28 PM
    GreenTexasTaco
    GreenTexasTaco Tiny Member
    Texas
    2022 Army Green TRD OR DCLB
    Unless the SR is wired differently than the other trim levels, I believe all you will need is the bed lights themselves.
    The bed lights turn on and off with the same switch that controls the lights on each side of the third brake light at the top of the cab (“off/door/on” switch in the switch panel left of the steering wheel). There should be wiring harnesses run to plug in the OEM bed lights behind each tail light.
    https://parts.toyotaofdecatur.com/p/Toyota__/Bed-Lighting-Kit/91139448/PT85735200.html
  3. Feb 14, 2022 at 4:39 PM
    lanchefan21
    The SR has no lights on the sides of the 3rd brake light or the cargo light switch. So I need the P/N for the lights, switch to put in the blank and the relay.
  4. Feb 14, 2022 at 4:40 PM
    Kyebasse
    Kyebasse Jd
    K
    21 Tacoma TRD Off-road
  5. Feb 14, 2022 at 5:04 PM
    GreenTexasTaco
    Texas
    My bad! I could have sworn my buddy’s 2021 SR had the toggle switch for the lights from the factory.
  6. Feb 14, 2022 at 5:17 PM
    Clearwater Bill
    Billy
    Largo Florida
    An alternative is under rail bed lighting by @mattgecko
    I suspect you'll find it to provide more lighting at a competitive price to the OE parts
  7. Feb 14, 2022 at 6:36 PM
    ambiguousfrog
    ambiguousfrog Member
    Scott
    Georgia
    2021 SR 4x4 Access Cab Silver Sky SX
  8. Feb 15, 2022 at 1:35 PM
    Haole Toy
    Haole Toy Well-Known Member
    Mauna Kea, AZ
    '21 SR 4x4
    My '21 SR has the switch and the "dead end" plug behind the taillights. They go hot when I turn on the cargo switch, so I might have to add these lights.
  9. Feb 15, 2022 at 2:15 PM
    GreenTexasTaco
    Texas
    Glad to know I’m not going crazy haha
  10. Feb 15, 2022 at 2:59 PM
    Crow41
    Crow41 Well-Known Member
    Lehigh Valley PA
    I believe the only the double cab version has everything pre wired. Lights go on and off with the cargo light switch.
  11. Feb 15, 2022 at 3:07 PM
    ambiguousfrog
    Scott
    Georgia
    Yes the 21' AC is pre wired behind tail lights.
  12. Feb 15, 2022 at 3:40 PM
    Crow41
    Lehigh Valley PA
    If you have a working prewired condition then you can add the lights for under $60. Easy install. You Tube has videos on the installation process.
  13. Feb 15, 2022 at 4:35 PM
    Nitro52
    Nitro52 Well-Known Member
    ct
    2022 SR/SX
  14. Feb 15, 2022 at 4:38 PM
    Haole Toy
    Mauna Kea, AZ
    '21 SR 4x4
    The kits on Amazon have good ratings...it's just plug and play for $35.
  15. Jun 13, 2022 at 7:54 AM
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    Pull out one of your tail lights to validate that you have the wiring. And if so, use a simple multi-meter to see if it has power when the interior lights are on. Amazon has the lights. The tail lights are easy to remove...and to do what I just said you only need to remove one.
