need offset of this gen 1 wheel
Discussion in 'Wheels & Tires' started by 2000SIG, Dec 2, 2010.
  1. Dec 2, 2010 at 7:14 PM
    2000SIG
    2000SIG [OP] Well-Known Member
    I woul need the offset of this wheel please.I have looked and found 2 different ones +15 and +22.
    thanks
    Marc
  2. Dec 3, 2010 at 5:59 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Stock backspacing on the 1st gens is 4.5". Need to know the width of the rim to calculate offset.
  3. Dec 3, 2010 at 6:18 AM
    2000SIG
    16x7"
    thanks
  4. Dec 3, 2010 at 6:21 AM
    TexasTacoma37
    Offset would be +12 mm then for 4.5" backspacing.
  5. Dec 3, 2010 at 6:27 AM
    2000SIG
    thanks KPT for the help.
    Marc
  6. Dec 31, 2010 at 1:01 PM
    2000SIG
    Im looking at this wheel and theres 2 backspacing/offset available.
    17" x 8.5"
    20offset 5.54BS 6x139.7
    and
    17" x 8.5" 0offset 4.75BS 6x139.7
    My truck will be riding withthe combo bilstein 5100/881 OME coils.The back will follow with the wheelers progressive aal and rear bilstein.
    My question is what wheel will be closer to the flares.Dont want the wheels and tires to be inside too much,but dont wan them too far out either.
    thanks and happy new year everybody.
    Marc
  7. Dec 31, 2010 at 4:18 PM
    TexasTacoma37
    What year truck? What size tire?
  8. Jan 1, 2011 at 10:25 AM
    2000SIG
    2004 tacoma xtra cab,265/70r17
    thanks
  9. Jan 1, 2011 at 10:27 AM
    TexasTacoma37
    Both of those wheels are going to sit further in than stock. Stock backspacing for 1st gens is 4.5".
  10. Jan 3, 2011 at 11:09 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    FWIW the stock 16x7 alloys on 1st gens are +15 mm offset. It's stamped right on the rims.
  11. Jan 5, 2011 at 9:45 PM
    wholesaler57
    wholesaler57 Member
    Florida
    prerunner SR5
    Does anyone know if the 16x7 stock aluminum wheel off a 1998 T100 will fit on a 2002 Tacoma 2 wheel drive? I know that the lug nuts are shouldered on the T100 and I have lug nuts to fit. I have the stock 16x7 steel wheels on the Tacoma now. Both wheels are the 6 hole wheel. I can pick up a set of T100 wheels cheap and my steel wheels have some rust. Any help appreciated, thanks.
