Need opinions and advice and pics if available
Discussion in 'Suspension' started by JohnnyBlazin44, Mar 20, 2012.
  1. Mar 20, 2012 at 7:49 AM
    JohnnyBlazin44
    JohnnyBlazin44 [OP] Well-Known Member
    Sault Ont. Canada
    06 access cab TRD
    satoshi grill by myself....but many future plans
    Hey guys I want a lift for my truck around 2 to 2.5 in so I wont need upper control arms .So was thinking the old man emu from toytech and installing without the the top plate spacer and 885 coils , My question is on my access cab would that be to much lift for not having uppers on it . Iam open to other opinions and options as well so please post up your 2 cents and pics if available.
  2. Mar 20, 2012 at 7:53 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    You should be good to go without new UCA's at 2-2.5". Once you get to 3" is when you may need them.
  3. Mar 20, 2012 at 8:03 AM
    JohnnyBlazin44
    Sault Ont. Canada
    06 access cab TRD
    kk but do you think it will be 2 to 2.5 on an access cab with that lift
  4. Mar 21, 2012 at 3:02 PM
    jtav2002
    Josh
    Reading, PA
    I'm not completely familiar with the OME stuff and the different coils and how much lift the various options give. Safe to say you'd be under 3" though without the spacers I believe they add 1/2 to 3/4" of lift.
  5. Mar 23, 2012 at 5:46 AM
    JohnnyBlazin44
    Sault Ont. Canada
    06 access cab TRD
    anybody else ??
  6. Mar 23, 2012 at 9:06 AM
    Gabe911
    Gabe911 Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    If you go with 885 coils you should be right under 3" inches.....I got 2.7 on my 2wd double cab with no top plate spacers. I had the tsb done to the rear and have the 1.5 aal ..my rear sits 3/4" higher than front...perfect! I also kept my stock UCA's and my alignment is fine...no vibes, drift, etc. love the ride and stance
  7. Mar 25, 2012 at 3:36 PM
    JohnnyBlazin44
    Sault Ont. Canada
    06 access cab TRD
    Thanks Gabe911
  8. Apr 2, 2012 at 6:13 AM
    JohnnyBlazin44
    Sault Ont. Canada
    06 access cab TRD
    So I think I will get the ome kit with 884 coils to stay under 3in of lift so my next question is should i get the 1.5 add a leaf or the 2in . I dont have the tsb
  9. Apr 2, 2012 at 7:14 AM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    well factory rake is about 1.5" higher in the rear...so if u get 2.5" from 884 coils you will want to get the rear lifted at least 1" to keep level ..its up to you how much the 1.5 aal will give u a little rake and the 2" will prob give u a hair more than factory
  10. Apr 2, 2012 at 7:43 AM
    bsteinkamp
    bsteinkamp Well-Known Member
    Bruce
    Memphis
    2011 TRD Sport
    6" Fabtech Lift LR UCA's Terra Grapplers 285/70/17 American Racing Wheels 17X9 Wind Deflectors
    Go with a 6" you'll love it!!
  11. Apr 2, 2012 at 7:48 AM
    mclovin
    mclovin chicka chicka, yeah!
    UK
    16 TRD OR DC Barcelona Red
    Prev, 04 Xtra Cab Prerunner, 12 SR5 4x4 AC
    i did 884's and dakars, came out with a pretty mellow rake. i did uca's just cause i don't want to rotate the tires every 1000 miles to keep the wear even.... im lazy.
  12. May 17, 2012 at 2:22 PM
    JohnnyBlazin44
    Sault Ont. Canada
    06 access cab TRD
    So if I order the OME lift from toytech 885 coils no top plate spacer whiche rear option should i get because I dont have the tsb pack. Ill get 2in one but just dont want more than factory rake . And also do I need to order any different bolts than what come with the lift kit for ther coilovers or rear lift.
  13. May 17, 2012 at 2:25 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    OME 885's without top plate spacers will get you 2 1/2 - 3" on an AC .
    2" AAL will get you close to level , Dakars will maintain factory rake
  14. May 17, 2012 at 2:43 PM
    JohnnyBlazin44
    Sault Ont. Canada
    06 access cab TRD
    Kk so 2in AAL is what i want cuz dakars are a little too much coin right now and I will just see how it goes for needing controle arms later if alignment isnt close enough.
  15. May 17, 2012 at 2:45 PM
    OZ-T
    Peter North
    British Columbia
    Yep
