Need opinions, and open to ideas
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tpeters91, Jan 30, 2011.
  1. Jan 30, 2011 at 8:56 AM
    Tpeters91
    Tpeters91 [OP] New Member
    Travis
    Ft. Hood, TX
    02 4x4. ToyTec Ultimate Lift
    I have an '02 trd 4x4. I want to lift it and would like to be able to fit 35" tires. Currently only seeing the Fabtech 6" lift that would allow those tires. Just looking for opinions about the lift or the whole project in general.
    - thanks
  2. Jan 30, 2011 at 12:11 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    get the sawzall out.
  3. Jan 30, 2011 at 3:32 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    when you start thinking of doing tires that big, it's also a good idea to regear. Since you have a 4WD thats two sets of gears. im not sure how much they run for a good set... Another thing that would be helpful for those giving tips is what do you MAINLY use your truck for in most cases if it's a DD a 3 inch lift will give you enough clearance and travel to do most off road trails. If you want my .02, 6 inches is to tall
