Need opinions, I have a stock 2018 Tacoma SR. Is it worth it to make off road mods to this trim
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Iwishiwasgoo, Dec 9, 2019.
  1. Dec 9, 2019 at 6:23 AM
    Iwishiwasgoo
    Iwishiwasgoo [OP] Member
    2018 Tacoma SR acess cab, 6 foot bed
    I have been browsing this forum for a while now and learning all I can. Ive noticed that almost all the mods and discussion revolve around either the TRD off road or the sport. Ive seen very little about SR or SR5 trims, so I was wondering what the general opinion would be about making off road upgrades to my SR, if the differences between the packages are enough to make it not worth off roading with. I will say that I have the 4 cylinder model, I know that's not ideal for off-road so lets not dwell on that.
    t0nyvalenzuela likes this.
  2. Dec 9, 2019 at 6:28 AM
    wolf2600
    wolf2600 Well-Known Member
    San Jose, CA
    2021 TRD-OR 6MT-SOLD
    Coyoza Tuned
    If it's 4wd, it'll be fine. Even if the 4cyl doesn't have as much power, you can always gear it to get anywhere you want.
    Toss in a Marlin Crawler and some decent tires and you'll out crawl the TRD OR trucks.
    xxTacocaTxx, Gunshot-6A and Boghog1 like this.
  3. Dec 9, 2019 at 6:31 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    The 4x4 system is the same across all models with the exception of the bigger rear diff on the offroad and pro models and the crawl control.
    So, you can get a lift and a air locker if you need it, otherwise a sr 4x4 will wheel the same as a sport or limited, you will need the air locker to compete with the offroad and pro models.
  4. Dec 9, 2019 at 6:33 AM
    Iwishiwasgoo
    No it's 4WD
    I figured the 4WD was the most important part, I worry most about ground clearance, so new tires and a suspension upgrade would be the first major mods that Id make. That crawler is something ive never heard of before so thanks for that!
    xxTacocaTxx likes this.
  5. Dec 9, 2019 at 6:34 AM
    FatherGreyBeard
    FatherGreyBeard Well-Known Member
    Old North State
    2018 Cavalry Pro M/T
    I would say yes if that fits your lifestyle. Do you off-road enough to justify the price of upgrades would be the question I would ask you. 4cyl vs 6cyl can be worked around with gearing. If your truck isn’t 4 wheel drive would dictate how aggressive you could be off-road as well. Tires would be a tremendous help and probably get you to most places you want to be.
  6. Dec 9, 2019 at 6:37 AM
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    You're good to go, mod it. I got a friend on 35's, regeared (and took the time to air lock front and rear), roll cage, etc. He's usually the guy I won't follow, and often can't follow.
    He bought the SR cause if you're going to change up everything anyways, why pay for the stuff you'll pull out. It's a great platform, and much less expensive to pay off so you can start to get to the good stuff!
  7. Dec 9, 2019 at 6:41 AM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    I would leave it alone and upgrade things you will use every day like the stereo. Other than that you could put slightly larger tires on the stocks like 265/75 because the stockers are kinda crap imho.
  8. Dec 9, 2019 at 6:42 AM
    Iwishiwasgoo
    That's re-assuring to hear. I don't know much about regearing or if I'll get into terrain where that's really necessary, but its good to know that if I want to make upgrades its not a waste of money thanks for your input! I will definitely be starting with tires and possibly some suspension in the next year here.
  9. Dec 9, 2019 at 6:46 AM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Sure it is worth making your truck more capable of going off road if you want to go off roading. Put on some all terrain tires and some rear lockers for starters. Take it easy out there, don't destroy your truck. You will figure out what you need after you start getting out where you want to go. You don't want to start buying a bunch of equipment and add ons that you would never use.
  10. Dec 9, 2019 at 7:06 AM
    Iwishiwasgoo
    Couldn't agree more. This is definitely going to be a slow process, when I start getting out there more ill have a better idea on what I want to do.
  11. Dec 9, 2019 at 7:08 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I see SR build threads on here frequently. I think you are good to go.
    shakerhood likes this.
  12. Dec 9, 2019 at 7:12 AM
    Clearwater Bill
    Billy
    Largo Florida
    This.
    'Upgrading' sans experience for your needs is like bench racing. Pointless.
    Tires are the biggest single improvement you can make. Then gain skill driving, learn how judge if you should proceed an obstacle or no, learn to recover if you do get stuck.
    Once you are to that point, then mod based on what you know for sure will make your offroad time better.
    Malvolio and whatstcp like this.
  13. Dec 9, 2019 at 8:33 AM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Before tires, consider the normal recovery gear — shovel, traction boards, maybe a come-along and a compressor, etc. I rarely use my recovery gear, which means I don’t really need any mods for the way I use my truck. Until you know what you need, you don’t know what you need.
    Edit: changed to get these^ things before tires, because your stock tires might be fine for what you end up doing.
  14. Dec 9, 2019 at 8:43 AM
    @T.A.C.O.M.A
    @T.A.C.O.M.A Well-Known Member
    Los Angeles
    If it’s 4x4 you’re good to go! Build it!
    built 4x4 SR5 > stock pro
    Boghog1 and GreyBaldTaco like this.
  15. Dec 9, 2019 at 9:20 AM
    Iwishiwasgoo
    The compressor mod is something that's already on my list of things to do, the recovery gear is a good look though. Ill look into that thanks
    Malvolio[QUOTED] likes this.
  16. Dec 9, 2019 at 9:33 AM
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    Nothin at all wrong with deckin out an SR.
    Just do some minimal purchases not spending alot of money then let the mission drive the gear.
    whatstcp and GreyBaldTaco like this.
  17. Dec 9, 2019 at 9:33 AM
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Really the biggest functional difference between the OR and the SR is the rear locker. You'll have to figure out how far you're going to take your truck in the off-road scene. If you're just trying to get to some squirrelly spots to setup camp and you might encounter a boulder here and there - get some minor armor, bigger tires, and a basic suspension upgrade and be happy. If you're rock crawling every weekend, ding the piss out of your rocker panel, can't keep the rear bumper intact, have to drive your truck in the slow lane with the hazards on bc you went full send and grenaded something in your drivetrain, think chicks dig trail rash like they dig battle scars, etc. then you can always get 35's, re-gear, and drop in a locker and be on-par with a built TRD OR.
    AKGSD and @T.A.C.O.M.A like this.
  18. Dec 9, 2019 at 9:51 AM
    MoneyMan55
    MoneyMan55 Licensed Master Electrician
    Doug
    South Central PA
    2017 DCSB SR5 Blazing Blue Pearl
    Is 4WD available on the 2.7 engine?
  19. Dec 9, 2019 at 10:21 AM
    trackdaybro
    trackdaybro Well-Known Member
    I think in access cab only.
    whatstcp[QUOTED] likes this.
  20. Dec 9, 2019 at 10:28 AM
    MoneyMan55
    Doug
    South Central PA
    I think that's correct.
    trackdaybro[QUOTED] likes this.
