Need opinions/info on pending chainsaw purchase
Discussion in 'Off-Topic Discussion' started by TL697, Nov 23, 2009.
  1. Nov 23, 2009 at 6:02 PM
    TL697
    TL697 [OP] Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    I have a Stihl MS 180 that I've had for 5 or so years. Before moving to CO, it was plenty of saw for my needs.
    Now, living at 9500 feet in the CO mountains, I need to cut firewood to heat my home. Approx. 5-6 cords per season. My MS 180 is just not up to the task... It would be good as a de-limbing and back-up saw, though.
    I'm ready to pull the trigger on a Stihl MS 390 w/ a 20" bar ($479.00)
    Local Stihl dealer is great - honest and helpful (sold me a $4 fuel line instead of taking my saw in for service...)
    Let me know what you think?
    Thanks in advance,
    Troy
  2. Nov 23, 2009 at 6:07 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    i have a magnum 066 and i love it. it was my dads for years and it stills runs great and cuts anything. its got a 36 inch bar on it
  3. Nov 23, 2009 at 6:10 PM
    TL697
    Jacksonville, FL
    That might be a tad bit of overkill for me... :eek:
  4. Nov 23, 2009 at 6:11 PM
    psycho
    psycho Well-Known Member
    missouri
    08 tacoma TRD DBL cab
    Toy-Tec 3" W/rear AAL and diff drop
    cant go wrong with a stihl. ive got a stihl and a husqvarna, love em both
  5. Nov 23, 2009 at 6:17 PM
    fighthedude
    fighthedude Active Member
    NorCal
    MaybeSomeday
    That should work just fine for you. I would also recommend the MS 361. It is apart of the professional series. Used them all summer and worked like a champ. Either way go with Stihl.
  6. Nov 23, 2009 at 6:21 PM
    TL697
    Jacksonville, FL
    The 361 would be nice... lighter but about same HP...
    But... $600...
    I'm already stretching my budget for the 390... I like to keep 2+ extra chains handy, so even purchasing the 390 with 2 extra chains, I'll be in the $500 range already...
  7. Nov 23, 2009 at 7:36 PM
    MattN03
    MattN03 Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    I bought a Stihl Farmboss 290 back in January this year after a major winter ice storm. This thing has been the most reliable and best running saw I've ever been around. I used it clean up our property after the ice storm, but have continued to use it through out the year. There have been several trees that needed to be taken down and I've done it w/o an issue with my Farmboss 290. Mine has a 18" bar and just recently, I cut a 36"-42" diameter white oak tree trunk (50' long) into 4' sections and it had no problem doing this. I'd buy another Stihl in a hearbeat and highly recommend them. I'm sure you can't go wrong with any of them if you pick up the correct size. Here is a pic of the white oak I just finished sawing up.
  8. Nov 23, 2009 at 7:42 PM
    TL697
    Jacksonville, FL
    Good to hear...
    The 290, 310, and 390 are the same saw with different displacements - 3.8, 4.0, and 4.3 BHP respectively...
    So, I'm basically getting a "Farm Boss" with a little more power, but the same weight...
  9. Nov 23, 2009 at 8:02 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    X2 on the 029 Farm Boss. I've had mine with a 20" bar for around 10 years now and it still runs flawlessly.
    Marc M
  10. Nov 23, 2009 at 8:15 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    I cut a lot of wood and it's the primary heat source for my home here in the NW (where we have long wet cold winters). Go with a 30" bar. My last Stihl had a 20" bar and I replaced it with a 30". I replaced it with the Stihl MS660 Magnum about a year ago and it has a 30" bar and is about the lightest weight for that power/bar available.
    I have only cut 5-6 cords of wood with it thus far so can't speak to it's longevity.. but I love it. A great saw. And I've cut plenty at 9k feet and it does great!
    A Stihl is a saw for life. Well worth the investment. Mine cost me just under $900. I'll bet if you have a good relationship with a dealer you could probably do even better, who knows?
  11. Nov 23, 2009 at 8:19 PM
    TL697
    Jacksonville, FL
    That is just not in my budget right now... Also, not much need for a 30" bar around here... The largest trees I will more than likely be cutting would probably be in the 18" range...
  12. Nov 23, 2009 at 8:24 PM
    mntbiker2008
    mntbiker2008 First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
    stihl for sure! never had any issues!
    btw... nice flex pic! hahaha :D
  13. Nov 23, 2009 at 8:40 PM
    mountainwolfpup
    Vancouver, WA
    OK, fair enough.. the Stihl MS660 Magnum is a bit overkill. Even for big trees a good 20" bar can tackle them. And I know you said you were on a budget. Sorry. Guess I just wanted to tempt you. When you pull the Stihl MS660 Magnum out of your truck and head for the fallen tree everyone around is in awe.. it's an impressive saw! And you can upgrade it to a max of a 36" bar if needed.
    OK, OK.. so I guess my advise is to stick with Stihl. Go into that shop with the money you have budgeted and say, "Give me the best saw for my money". Pretty much any Stihl will do you well for many many years. Sometimes they throw in the extra chains for a discount if purchased at time of saw.
    Best wishes.
  14. Nov 23, 2009 at 8:44 PM
    TL697
    Jacksonville, FL
    Yeah, I plan to buy at least 2 additional chains at time of purchase...
  15. Nov 24, 2009 at 4:12 AM
    MattN03
    Bluegrass State
    I was at my Stihl dealer last week and they were offering a free carrying case
    with the purchase of a Farmboss. All I got was a bar/chain cover when I bought mine...:( Hopefully, you're dealer in CO is offering the same thing!
  16. Nov 24, 2009 at 4:13 AM
    MattN03
    Bluegrass State
    I wish I had bought a 20" bar instead of the 18" after cutting down this large white oak. Does the 290 seem to have plenty of power-even with the 20" bar?
  17. Nov 24, 2009 at 4:17 AM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    my buddy works for a stihl shop they had one in there with atleast a 36 inch bar and the what he said was the biggest motor they offered it was like 50 pounds of pure 2 stroke
  18. Nov 24, 2009 at 8:18 AM
    Kuneff
    Kuneff Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    I have a Stihl 024AV. it works good, but I think my Husqvarna 445 is better. 18" bar, $319 at Lowes. Chains are $22 each.
    Its worth checking them out.
  19. Nov 24, 2009 at 8:21 AM
    Kuneff
    Kuneff Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    My buddy has one of these...
    Stihl 090, his has a 54" bar if I remember right... That saw would cut down plenty of fire wood for ya..... :D
    It will cut deep... :D
  20. Nov 24, 2009 at 9:48 AM
    TexasIslandBoy
    Andrew
    South Texas. SPI
    thats the one the o90 thing was like 60 pounds
