need opinions on braking power
Discussion in 'Wheels & Tires' started by ToyTaco, Feb 9, 2011.
  1. Feb 9, 2011 at 12:29 PM
    ToyTaco
    ToyTaco [OP] For the Retards, Im a Female
    Kristin
    Newark, DE
    '10 TRD Sport 4x4 modified
    hey guys just wanted some opinions. This is basically my first lifted truck and all, and need some opinions on the braking power for it. Since I put the lift on with bigger tires etc I noticed my braking power isnt as good as when it was stock. Im guessing I will need to upgrade everything, but wanted to know whats the best brand to upgrade to and if i should not just upgrade the brakes but the rotors etc as well? thanks in advanced!
  2. Feb 9, 2011 at 5:41 PM
    Blkturbo!
    Blkturbo! Well-Known Member
    Sean
    Henderson, NV
    08 Tacoma; 05 Seadoo RXP; 94 Turbo Supra
    Icon Coilovers, Downsouth UCAs, rear Icon "2.5" shocks and Toytec single AAL. Still gotta do exhaust, dark headlights and re-gear the rear diff.
    I looked at your build but unless i missed it, i dont know what size tires you have....just curious.
    Meanwhile, in my personal opinion/experience, i doubt changing pads alone will give you much braking power back.
  3. Feb 9, 2011 at 5:42 PM
    Blkturbo!
    Sean
    Henderson, NV
    "for the retards, im a female"....i just noticed that, lol
  4. Feb 9, 2011 at 5:48 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    you can keep stock rotors and just upgrade your pads to hawk hps.
  5. Feb 10, 2011 at 4:39 AM
    ToyTaco
    Kristin
    Newark, DE
    the tires are: LT275/70R18, i had it in my build later on in a post
  6. Feb 11, 2011 at 10:16 PM
    sflguy4u2
    sflguy4u2 Member
    Pembroke Pines, FL
    10 Prerunner Dbl Cab SR5
    Bed mat.......Chrome Tip....Hard ARE Tonneau cover
    I have '10 Tacoma Prerunner Dbl cab.....one of the things that almost led me not to buy the truck was the soft pedal feel of the brakes and long stopping distance.....everyone I tried did it....I've had a couple of close calls during sudden needed stops...I do find pumping the brake helps a bit....anyone else have this issue.
  7. Feb 11, 2011 at 10:19 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Larger, heavier tires are going to reduce braking efficiency a bit. Probably not a whole hell of a lot you can do about it.
