Need opinions on this first gen...
Discussion in '1st Gen. Tacomas (1995-2004)' started by motodude95, Oct 29, 2017.
  1. Oct 29, 2017 at 4:58 PM
    motodude95
    motodude95 [OP] Well-Known Member
    Jim
    2012 MGM TRD Sport DCLB, OME 886s, 33s
    Found a sweet '98 sr5 with low miles. 145k on the dash. 2wd. Southern car, shouldn't have any rust. 3.4L v6.
    Going to check it out later this week. Need some TW advice from you first gen guys. Guy is asking $6.5k but KBB is half that.
    What's a fair price? What are the key things I should be looking out for? Rust? Mechanical issues?
  2. Oct 29, 2017 at 5:26 PM
    Floridagulfcoasttaco
    Floridagulfcoasttaco Well-Known Member
    Noah
    1999 Tacoma extended cab prerunner
    I have that exact truck even the color and running boards . I purchased it about 2-3 years ago with 107k for 8g in Florida. Hope that helps gauge the price but then again I think I got a good deal but 6.5g seems fair looks like a clean truck
  3. Oct 29, 2017 at 5:29 PM
    Dr. Mantis Toboggan
    Dr. Mantis Toboggan Well-Known Member
    2017 TRDOR 4x4 & 2000 TRD TACO 4x4
    Check for rust even though it's a southern truck. These frames can rust anywhere.
    Also see when the timing belt was last changed.
    2BeersPlease and motodude95[OP] like this.
  4. Oct 29, 2017 at 5:32 PM
    motodude95
    Jim
    Thanks guys!
    Oh damn these 3.4l v6's have timing belts huh? Hopefully that was taken care of.
  5. Oct 29, 2017 at 5:50 PM
    Dadypig
    Dadypig Aka daddy pig
    Jaime
    East bay Kali
    2001 silver extended cab sr5
    Stock for now
    Fair priced truck,clean title?
  6. Oct 29, 2017 at 6:01 PM
    motodude95
    Jim
    Yeah clean title. The price isn't bad but I feel like it could be a bit lower for a 2wd access cab.
    Did these trucks fall under any frame recall?
  7. Oct 29, 2017 at 6:21 PM
    Dr. Mantis Toboggan
    Yep. Too late for a replacement though.
  8. Oct 29, 2017 at 6:24 PM
    2BeersPlease
    2BeersPlease Well-Known Member
    I don't think the KBB is all that relevant when it comes to vehicles like the first gen Tacomas. The value is really determined by the market and what someone is willing to pay. Clean first gens get top dollar because they've become a desirable vehicle.
    That price isn't unreasonable, especially for my part of town. If everything checks out, I'd be happy to pay $5500~$6000. You know there's easily another 100K miles in that truck, assuming it's mechanically sound of course.
    Itchyfeet and motodude95[OP] like this.
  9. Oct 29, 2017 at 6:30 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    i personally think its a little high since it isnt a 4x4. then again these things sell for rediculously high prices on the regular.
    motodude95[OP] likes this.
  10. Oct 29, 2017 at 6:31 PM
    Dadypig
    Jaime
    East bay Kali
    Stock for now
    Low miles extra cab prerunners are going for that price all day long here in Cali,usually don’t last more then a few hours when posted.Might be able to come with cash in hand and knock it down a few bucks.
  11. Oct 29, 2017 at 6:31 PM
    motodude95
    Jim
    I'm mostly concerned about the rust at this point. Were all frames recalled for these years or just certain trucks? How obvious would the rust be?
  12. Oct 29, 2017 at 6:33 PM
    Dadypig
    Jaime
    East bay Kali
    Stock for now
    Bring a hammer and a flashlight.If it sounds solid your solid,if hollow then run!
  13. Oct 29, 2017 at 6:35 PM
    devinzz1
    devin
    2023 aclb trd or mt
    bring chipping hammer or some kind of pick and tap around for soft spots.
  14. Oct 29, 2017 at 6:36 PM
    poseytaco
    poseytaco Well-Known Member
    Nicholas
    Indiana
    2012 Off-road
    Yes. Toyota bought my 99 back from me. Said it didn’t pass frame inspection. I bet I could have driven it another 100,000 miles, but they offered me too much to refuse.
  15. Oct 29, 2017 at 6:38 PM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    I think its likely a fair price, but of course up to you.
    Good mileage, any papers on it? Carfax? Accidents?
    Rust. Check everywhere, hit that frame with a hammer and see where you're at on this. This is the death knell for our rigs, mechanical can be fixed. Rust: only a frame will fix it or extensive welding/boxing and may not be worth it.
    If the above checks out, I'd snag it. A clean Gen 1 is the best looking truck on the road. or off.
  16. Oct 29, 2017 at 9:07 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Like all above, frame, timing belt. Also be checking for other things like, tread left on the tires, if the AC works(should get down to 50 degrees if not lower on max, bring a meat thermometer to put in the vent to check), diff lock if applicable, fluids(check for larger fragments in oil and transmission oil with a sheet of white paper. Also check under the oil cap, if there is milky looking sludge under it, it could be the start of head gasket, cracked block or something of the sorts. At the beginning of water getting in the oil the dipstick won't always show.) Have the owner start the vehicle while you look at the engine with the hood open to check for bad motor mounts(Little shake on crank=good, lot of shake=not good) If you can get a hold of a code reader, after the test drive, plug it in and check for pending codes. Also while your under the truck checking the frame, look for excessive oil build up anywhere indicating bad seals.
    Keep in mind most of these things aren't deal breakers, just things to look out for, cause repair costs can add up quick.
    Good luck!! :thumbsup:
  17. Oct 29, 2017 at 9:20 PM
    motodude95
    Jim
    Thanks guys! Will keep you updated as to what happens
    RedManRocket likes this.
  18. Oct 30, 2017 at 9:56 AM
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    Check value in the " Black Book" that Banks & Car dealers use -has pricing for the local areas -not just nationwide .
