Need opinions
Discussion in 'New Members' started by Bandit1911, Feb 27, 2025.
  1. Feb 27, 2025 at 11:28 PM
    Bandit1911
    Bandit1911 [OP] New Member
    I just bought a 2005 Tacoma 4.0L 138k miles and I noticed heat starts blowing cold intermittently at idle and blows hot again the second I touch the gas. Took it back to dealership where they pressure tested it and everything checked out fine heat was working normal after I topped it off and bled air out. For a few days and last night it started blowing cold again, so I checked fluids antifreeze level is normal dipstick is clean however I found moisture in the threads of the oil cap is it related? Any advice or opinions welcomed.
    buckhuntin-tacoma likes this.
  2. Feb 28, 2025 at 12:02 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Welcome to Tacoma World. The water pump pushes coolant through the system, and for heat to work it has to flow through the heater core. It could be that the water pump isn’t doing its job any more, could be the heater core is partially blocked, or could be something else entirely. Moisture in the oil cap could be due to not getting warm enough / only driving short trips, but can also be a symptom of other not so fun things. Unfortunately no way for us to tell over the web so you’ll either have to start diagnosing yourself, find a mechanic friend, or take it somewhere. Good luck.
    usmc2msu and buckhuntin-tacoma like this.
  3. Feb 28, 2025 at 12:23 AM
    Bandit1911
    Thank you was just trying to figure out if they could possibly be connected as milky residue would indicate a serious problem such as head gasket, intake ect if I have a leak would it be possible for air to get into the cooling system causing the intermittent loss of heat or unrelated? Unknown if It leaks antifreeze it was low when I first noticed and had to add to it for a few days but appears to remain stable now. As for travel I drive 30 minutes average per trip.
  4. Feb 28, 2025 at 5:24 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW! Good luck!
  5. Feb 28, 2025 at 5:49 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe check that plastic coolant pipe under the intake isn’t cracked.
  6. Mar 12, 2025 at 2:23 AM
    Bandit1911
    Well update truck was taken to dealership. I advised them I believe it has leaking head gasket or intake gasket, they called back few days later to tell me there's air getting into the system even tho I told them that when I dropped it off so they replaced heater core got truck back today problem remains so ill be calling them back tomorrow keep in mind I haven't even made a payment on it yet 05 Tacoma will update.
    Steves104x4 likes this.
  7. Mar 12, 2025 at 2:31 AM
    World2405
    World2405 WUBBA LUBBA DUB DUB!!!!1!
    Delaware
    2023 Toyota 4Runner
    Hi there
