Need outdoor electrical advice
Discussion in 'Off-Topic Discussion' started by LivinOnEdge, Apr 5, 2021.
  1. Apr 6, 2021 at 5:00 PM
    #101
    LivinOnEdge
    LivinOnEdge [OP] ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Not my house I guess. Whole thing is 14/3
  2. Apr 6, 2021 at 5:04 PM
    #102
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    If it was wired under an old standard, that's fine - it's grand-fathered, but any new alterations or updates will have to conform to NEC & local codes.
  3. Apr 6, 2021 at 5:07 PM
    #103
    LivinOnEdge
    Land of The Lost
    Gotcha, thats fair enuff.
  4. Apr 6, 2021 at 5:30 PM
    #104
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Too much crack on my part. Thanks for the correction. 14/3 is 15 amp.
  5. Apr 6, 2021 at 5:38 PM
    #105
    LivinOnEdge
    Land of The Lost
    My house is old af apparently.
  6. Apr 6, 2021 at 5:39 PM
    #106
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    @LivinOnEdge
    @LivinOnEdge
    Drop the sub panel at the main. Run 1 inch conduit from soup to nuts in a trench at depth and pull 12/3. Run the tape, backfill with sand and install a watertight gfi receptacle. Wire the sub panel near the main from the 50 and put a modern 20 breaker for this branch. Be careful not to introduce a floating neutral with the sub.
    06Tacooo and LivinOnEdge[OP] like this.
  7. Apr 6, 2021 at 5:41 PM
    #107
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    NEC is pretty clear.
    06Tacooo likes this.
  8. Apr 6, 2021 at 5:48 PM
    #108
    LivinOnEdge
    Land of The Lost
    You guys have given me so many options and I appreciate it. Wish I could afford a modern 200amp panel upgrade. Need to mul over my options.
    Toyko Joe likes this.
  9. Apr 6, 2021 at 5:52 PM
    #109
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    Park your badass Taco in the yard, plug into the inverter and done. At least you can power a light on your truck so you can sit there and look at it.
  10. Apr 6, 2021 at 5:54 PM
    #110
    LivinOnEdge
    Land of The Lost
    Lmao
    Spare Parts and tcjacado like this.
  11. Apr 6, 2021 at 6:13 PM
    #111
    tirediron
    And, you'll only need 12/3 if you're running 220v; for 110v 12/2 is all that's required.
    Lawfarin likes this.
  12. Apr 6, 2021 at 6:54 PM
    #112
    Toyko Joe
    Toyko Joe Here for the pictures
    Unless you want two circuits...
  13. Apr 6, 2021 at 7:11 PM
    #113
    tirediron
    Then you should be running two breakers. You can go eight outlets on one breaker.
    10tacotrooper likes this.
  14. Apr 8, 2021 at 7:00 AM
    #114
    LivinOnEdge
    Land of The Lost
    Quick update. Was able to locate the 20 amp breaker I needed and bought of few of them because, why not. When they come in, I'm going to continue using the current wire that's already been run. $5 and about 20 minutes for the job.
  15. Apr 8, 2021 at 7:12 AM
    #115
    tirediron
    Not quite that simple; you can't (safely or legally) connect 8 AWG to a regular two-pole outlet. You will need to (code permitting) add a box adjacent to the outlet and transition from 8 to 12 AWG.
  16. Apr 8, 2021 at 7:14 AM
    #116
    LivinOnEdge
    Land of The Lost
    Why can't you use larger wire on an outlet? I've been told that's fine.
  17. Apr 8, 2021 at 7:27 AM
    #117
    tirediron
    Because it's too large; your local code may vary, but IIRC, 12 AWG is the largest you can use on a standard two-pole outlet. The problem is that the wire is so large in diameter that it would not sit properly on the mounting screws and give the correct contact area, and likely won't stay secured either. Regular outlets are only meant for single-conductor cable. You could run the 8 AWG into the box, and pig-tail 12/2 off of that, but if you're going to do that, check local code and if you do it, make sure you solder the conductors, do not just use a "wire nut".
  18. Apr 8, 2021 at 7:30 AM
    #118
    LivinOnEdge
    Land of The Lost
    Sounds like a PITA lol, might be easier to buy new 12g and just re-run it the right way then.
  19. Apr 8, 2021 at 7:34 AM
    #119
    Toyko Joe
    What you are saying is technically correct if the outlet is sized for 12g wire only. However, if the both devices have capacity and designed to fit each into component you’re ok. (In which case most 20a GFCI outlets are only sized to fit 12g max) It’s like sizing for voltage drop. The intent of the breaker is to limit current over the conductor so that it doesn’t heat up and cause a fire. If you oversize conductors you will have less voltage drop and your conductors will actually be cooler when running full amperage for the breaker size which is technically 80% of the rated amperage.
    summary: @tirediron is correct you will need to have a junction where you transition from your existing 10g conductors to 12g that install to the 20a GFCI. This is because the device is not designed to fit larger than 12g wire.
    LivinOnEdge[OP] likes this.
  20. Apr 8, 2021 at 7:36 AM
    #120
    Toyko Joe
    Not a PITA, just simply get quick connectors and put the existing wire and add in 12g splice to the outlet, tuck it into the back of the junction box. Done
