Need Painting Advice
Discussion in 'Detailing' started by Bagman, May 16, 2013.
  1. May 16, 2013 at 5:33 PM
    Bagman
    Bagman [OP] Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    I'm thinking of buying this grille and then color-matching it myself. It's brand new, aftermarket with a black surround. I want to paint it Barcelona Red.
    My question is regarding prep. Since it's new, would a light sand with say 1000 grit, spray with fillable primer, couple coats of adhesion promoter, then color spray work or is there something else I should do? I would also clear after painting.
    Sorry if this is posted in the wrong forum - wasn't sure which was more appropriate.
  2. May 17, 2013 at 4:08 PM
    Bagman
    Area 51
    Really guys? nothing.....
    wrong forum?
  3. Jun 12, 2013 at 10:40 PM
    66chevelless511
    66chevelless511 Die hard Toyota fan!
    Idaho
    2013 Black TRD Off Road
    3" lift, air bags in the rear used when trailering
    Didn't research details of what's on it as is, but my painting practice on new materials for a color change only is to use either SEM "scuff and clean" with a grey scotchbrite pad, or comet and a grey scotchbrite. Scuff it good, color right over that (no prime necessary, just have enough color to hide), then clear. This is a relatively common paint shop practice. Hope it helps!
  4. Jun 13, 2013 at 5:16 AM
    Bagman
    Area 51
    Thanks for the advice. Didn't want to buy a new grille then mess it up cause I didn't know what I was doing. What about using adhesion promoter before painting?
    Thanks again.
  5. Jun 14, 2013 at 5:07 PM
    66chevelless511
    Idaho
    If it has any kind of finish on it now, i personally wouldn't worry about am adhesion promoter... But if it is bare plastic, an adhesion promoter is agood idea, it also helps with static on the plastic. This has been my experience anyway. Have fun! I may be doing somethings similar, as i would like to color match mine (may try to paint over the chrome, but that isn't something I've ever done, it may not scuff as i expect, and may want to save the chrome one.) Where'd you find this grill?
  6. Jun 15, 2013 at 4:15 AM
    Bagman
    Area 51
    Thanks again. I think I'll use the adhesion promoter. Couldn't hurt.
    Here's the grille:
    I went the plasti dip route with my grille. Looks good but would prefer to color match. That said, I would like to save the original "chrome" grille just in case.
