NEED quick 1st gen susp help..(trucks on the lift)
Discussion in 'Suspension' started by J Hoss, Apr 2, 2011.
  1. Apr 2, 2011 at 10:59 AM
    J Hoss
    J Hoss [OP] Well-Known Member
    Justin
    Round Rock, Tx
    4runner Trail Edition w/ KDSS
    Duratracs
    Toytec c/o's Dakar rears bilsteins all around.
    2 issues, one bolt rusted in on the rear.Hack saw?
    bigger issue...didnt get the exhaust relocation bracket, is there a work around with out waiting a few days fr the $12 part (cutting the exhaust? )
    Thanks in advance [kicking myself for missing this during my weeks of research]
  2. Apr 2, 2011 at 12:40 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    Now: 12 T4R SR5 Then: 99 - 3.4L SR5 4WD
    Wheeler's/Alcan 5-pack leaf springs, Bilstein 5100's front and rear, OME 881's, de-badged, Jungle Fender Flares, Herculined bed, HomerTaco grille, Anzo headlights, clear corners, CVT Mt. Bachelor RTT, custom bed rack & CBI sliders
    for the stuck bolt grab some PB Blaster (you have a can handy right?), spray liberally and let it soak in. Not sure about the exhaust...
  3. Apr 2, 2011 at 12:52 PM
    PBPoison
    PBPoison Member
    Lon
    NOVA
    TBD
    For your rusted rear, can't go wrong with trying some lube. If that doesn't work, heat...just try not to catch it on fire because the lube is flamable. All else fails, get out the saws-all and cut the bolt, might have to do both sides because it can be cold welded in the bushing. Let the weight of your tool do the work so you don't wear out the teeth.
    As for the hanger, you can use some metal strapping for a temporary fix until you can get the relocation bracket.
  4. Apr 2, 2011 at 1:08 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    If it is the spring eye bolt that is stuck, I used a grinder with a cut-off wheel. Went through like butter.
  5. Apr 2, 2011 at 1:53 PM
    J Hoss
    Justin
    Round Rock, Tx
    Duratracs
    thanks I have a buddy doing it at NTB, used a sawsall...of course now the dakars appear to be too short :/
  6. Apr 3, 2011 at 12:24 AM
    J Hoss
    Justin
    Round Rock, Tx
    Duratracs
    2003 tacoma 4x4...got the right springs...center pin wouldnt line up, is this due to the shocks being bolted up first? Should the leaves go in, then the shocks?
    The Axle came too far forward and the center pin didnt line up. is it a matter of bolting up the leaf first, then shocks?
  7. Apr 3, 2011 at 6:25 AM
    JDMcQ
    Leaves first, then shocks. Can't see your pictures, too small.
  8. Apr 3, 2011 at 8:24 PM
    J Hoss
    Justin
    Round Rock, Tx
    Duratracs
    cant get the thumbnails reduced, but hopefully everyone knows about the ctrl + mouse scroll to reduce page size :)
  9. Apr 4, 2011 at 4:51 AM
    JDMcQ
    Maybe it was my computer, but the pics were tiny, thumbnail sized. I can see them now.
    Did you get this straightened out?
  10. Apr 4, 2011 at 10:07 AM
    J Hoss
    Justin
    Round Rock, Tx
    Duratracs
    Thanks for the help guys...its still at the shop in pieces, my buddy who is install is out today...
    http://www.tacomaworld.com/forum/1st-gen-builds/83702-steve-o-77s-build-pics-2.html
    Ive been referencing Steve O's build. My shackles (pic 1) face toward the truck where as steve's face backward. Is that just how they adjust once the suspension is loaded?
    PSU,
    Ill pass along the recommendation to unbolt the shocks (hopefully that allows some wiggle room.
    Don't believe they came with longer u bolts, thought the Toytec Ultimate came with those.
  11. Apr 6, 2011 at 8:22 PM
    J Hoss
    Justin
    Round Rock, Tx
    Duratracs
    Lifts on! (Thanks again John!) Ill snap a couple pics in the morning, got it back, and home, and the bolts on the coilover tower were loose though :/ . I tightened them down with a 14, does anyone know the torque specs so I can have them hit with some air in the morning?
  12. Apr 7, 2011 at 4:30 AM
    JDMcQ
    Glad you got it done Justin. Can't wait to see the pics and your impressions of your new ride.
  13. Apr 7, 2011 at 5:09 AM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    Do the Conrad special on the exhaust. Golden. :)
  14. Apr 7, 2011 at 4:18 PM
    J Hoss
    Justin
    Round Rock, Tx
    Duratracs
    Ill skip the whole teaser 1 pic at a time thing :D
    lift F&R and some new meats :)
  15. Apr 7, 2011 at 4:22 PM
    JDMcQ
    Looks great Justin!
  16. Apr 7, 2011 at 4:22 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    sweet man! glad you figured it out!
