Need quick response from CB owners!
Discussion in 'Audio & Video' started by DueNorth, Jul 18, 2010.
  1. Jul 18, 2010 at 9:58 AM
    DueNorth
    DueNorth [OP] Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Hey Guys, just in the middle of installing my CB and so far i got the antenna mounted and coaxial cable ran down along the frame. I'm running the cable along the driver side and i figure i may as well go up through the rubber grommet underneath the driver seat. So my question is this...
    Did you guys remove the seat (?) to give you room to access the hvac vent and and run the cable from the grommet to the vent?
    or is there another way to run the cable without removing the seat or from a different access point, etc?
    What did everyone exactly do to run there cable into the cab?
    I should also mention that i'm going to be mounting my cb in the compartment located between the front seats....
    Thanks for the help!
  2. Jul 18, 2010 at 10:01 AM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    On my 1st gen i pulled the carpet back and found a rubber grommet underneath where the drivers floormat would be and pulled it through there.
  3. Jul 18, 2010 at 10:08 AM
    DueNorth
    Thanks for the response, ever install one on a 2nd gen tho?
  4. Jul 18, 2010 at 10:35 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i ran mine in the grommet under the passenger seat. pushed up the carpet and ran it to the door jam cover w/o removing the seat. should be able to do the same on the drivers side
  5. Jul 18, 2010 at 11:58 AM
    DueNorth
    Thanks for the help Jhodge83...
    I got it all figured out now. I removed the DS door sill and seat bolts so that my hand could fit and slide easily under the carpet over to the grommet. I took the grommet out and cut an X pattern so that i could slide the cable in. Then seated the grommet and pulled the cable out of hole where the vents are. I then went from the vents to the center console. So its all installed now.
    I went with a Cobra 19 for space reasons but with the cable attached to it on a straight angle from the back i've noticed i can't fit the unit standing straight up in the compartment.
    oh well, this is just temporary for the upcoming SONTT trail run next weekend, but for a more permanent CB i think i may go with a Cobra 75...
    Of course, the positive n negative wire from the CB is too short to reach the battery so i guess i gotta pop over to radio shack for some more wire...
  6. Jul 18, 2010 at 12:30 PM
    beef TACO no rice
    beef TACO no rice Well-Known Member
    Orlando, FL
    07 taco single cab
