Need Rear Axle Assembly for 3.4 double cab prerunner
Discussion in '1st Gen. Tacomas (1995-2004)' started by HellOfATruck, Oct 8, 2021.
  1. Oct 8, 2021 at 11:29 PM
    HellOfATruck
    HellOfATruck [OP] New Member
    SoCal(Upland)
    2004 Beige Tacoma V6 Prerunner DC
    I recently spun out and hit the drivers side rear pretty bad. axle is bent and i need to get a new one, but i dont know where exactly to start. Would i be able to do a swap with a 3rd gen 4runner? Or what would i be able to do?
  2. Oct 9, 2021 at 3:40 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No.
    4Runner uses coils, panhard bar, and a different shock mount setup.
    Bump stops are also located differently.
    Black DOG Lila likes this.
  3. Oct 9, 2021 at 4:34 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  4. Oct 9, 2021 at 6:14 AM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Do you need a complete axle assembly? Just the brake/bearing/shaft sub-assembly? Is the axle housing damaged? You might save some money on parts by buying only the specific parts that are damaged, but the install will be simpler (and possibly cheaper, if you're paying a shop to do it) if you get a complete axle assembly. If you're not sure, it's probably best to replace the entire axle assembly.
    Do you know what final drive ratio your truck came with? Since it's a Prerunner (not 4x4), you don't need to worry about matching the front diff, but the truck will drive differently (maybe better, maybe worse, it depends on how you use the truck) if you change the gear ratio. See this thread for help determining your original gear ratio: https://www.tacomaworld.com/threads/oem-gear-ratio-chart.365138/
    Did the truck come with an e-Locker? Locking and non-locking axle housings are different.
    Where are you located? Shipping an axle is an expensive pain, so best to look for one local.
  5. Oct 9, 2021 at 6:15 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I have an 8.4" non elocker axle assembly I could sell you.
  6. Oct 9, 2021 at 6:59 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    It is good to tell us where you are!
    Freight on a axle for 3000 miles might be just a little expensive.
    HellOfATruck[OP] and Kwikvette like this.
  7. Oct 9, 2021 at 7:54 AM
    Brojohanson
    Brojohanson Well-Known Member
    California
    2003 Dbl Cab Supercharged 3.4l 5 speed / 4x4
    I've got a rear end if you need one. South Texas.
    HellOfATruck[OP] likes this.
  8. Oct 9, 2021 at 9:30 AM
    Bivouac
    If OP needed to ask about a 4Runner axle housing They don`t have the skills yet like you will soon to say sure you can use a 4Runner axle Housing it just takes a little work.
    Interesting How the meaning of a little work changes person to person so much.
  9. Oct 9, 2021 at 3:53 PM
    HellOfATruck
    SoCal(Upland)
    Sorry, you guys are right i didn't provide enough information(i didn't get most of it until this morning when i visited the shop its at) or state that im in. I live in SoCal. So i need to get a new drivers side axle shaft, a new axle housing and im going to look into getting new leaf springs. im hoping the diff is still able to be used. The axle housing itself is toed in from where i hit the curb(it's about an inch difference compared to the other side). Im going the pretty expensive route and getting an O.E. housing from the dealer, mainly because my family is going to help me out with getting some stuff. i made sure to get the same housing i already have on.
    Thank you guys so much for the offers and being helpful, again sorry for not including the info
  10. Oct 9, 2021 at 3:55 PM
    HellOfATruck
    SoCal(Upland)
    I was thinking about using this as an opportunity to change to a locking diff, but im just gonna stick with what i got. i figure i can add a locker later on
  11. Oct 9, 2021 at 5:32 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Aftermarket locker is better anyway. And the 8.4 is a stonger diff than the 8" TV6
