Need rear bumper frame bolts
Discussion in '1st Gen. Tacomas (1995-2004)' started by climber-420, Sep 13, 2022.
  1. Sep 13, 2022 at 7:38 PM
    climber-420
    climber-420 [OP] I love tight cracks
    CO
    2004 Gold Ext Cab TRD 3.4L V6 Manual
    255/85/16 BFG KM2's, 3" OME lift, Dakar's, Nitrochargers, Grey Wire Mod, ARB Bumper, ARB CKMA12 air compressor, WIts End Pacifier, Warn M8000, Uniden 520 XL CB, rear diff breather mod, full time power to aux 12V outlets, Rago Fab ditch brackets, Titan Rod Vault, Extreme LED's front and rear,
    So I decided to cut off my rear bumper, because my new 4XInnovations bumper is being powder coated right now, and I'm trying to get ahead. That said, after I cut everything off, I am still left with 2 bolts that are now basically stuck inside the welded on nuts, on the inside of the frame.
    1 - how do I remove these? Heat with torch, and punch out, or drill out?
    2 - what is the frame bolt size (need QTY 4). I called the dealer up the road, and the parts guy of 18 years, had no idea, even emailed me the schematic he had, and it didn't even show the front or rear bumper on there.
    TIA.
  2. Sep 13, 2022 at 8:23 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Use PB blaster or something to soak them, and remove as you normally would any other bolt.
    Wack them with a mallet, to break up any rust.
    Heat definitely helps; no it absolutely helps.
    Take them with you to a hardware store and match the pitch/length (it'll be Metric, guessing 1.5 pitch like other stuff has been).
  3. Sep 13, 2022 at 8:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Small shops are easier to deal with.
    I remember when I was replacing some bolts, I grabbed a handful and asked the clerk if I can step outside to ensure I got the right size.
    This was at a local ACE (on 2 different occasions, in different cities). Because of that I'll gladly give them my business.
  4. Sep 13, 2022 at 9:47 PM
    02hilux
    Planet: EARTH
    I'm a cheap bastard. Hate paying metric price, lol. Just grab some grade 8 bolt (2" long 1/2-13), 1/2 washer, and 1/2-13 nylon nut. You can add 1/2 lock washer but not necessary.
