Need rear suspension info
Discussion in 'Downsouth Motorsports' started by laperlanegra, May 27, 2009.
  1. May 27, 2009 at 9:59 AM
    laperlanegra
    laperlanegra [OP] Active Member
    Deb
    Vista, CA
    08 PreRunner TRD Sport
    TRD Cat-back exhaust, Bilstein 5100's all around, TotalCHAOS UCAS, Toyota TSB & Toytec aal-tsb, tinted windows, LED HALO taillights (black housing);Wet Okole TRD front seat covers;Alpine MRX-F35 4 channel amp; Alpine MRX-M55 mono amp; Pioneer TS-SW2501S4 (2-10" subs); Kenwood Excelon CD receiver KGCX797; Polk AUdio DXi6500 components front and DXi650s rear plus Alpine rux-knob custom location
    Hey Sonny, I purchased the front 5100's for my 08 Taco & had Toyota install them. I asked them to level my truck & my truck is now higher in the front and about 1-1 1/2" lower in the rear. Before I return to ask them to "level" out the front (again), do you have any suggestions for raising the rear of the truck so it is now level with the front? Preferrably something other than blocks. I somewhat like the height of the front the way it is. Not sure if I should add another leaf (& I have the tsb mod) or get longer shocks. What would you suggest? Thanks for the time & info.
  2. May 27, 2009 at 10:01 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I'm not sonny but toytech makes an AAL for the tsb pack that might help you out
  3. May 27, 2009 at 10:25 AM
    laperlanegra
    Deb
    Vista, CA
    That sounds like the perfect answer. My rear shocks are stock, can I use the stock shocks with the Toytec AAL for TSB or should I upgrade the shocks? I'm concerned about length of shock & stock shocks being able to handle bumpy roads with new rear height. Thx for the Toytec info.
  4. May 27, 2009 at 10:30 AM
    DanGer
    That is a notable concern. Hopefully someone else can address that, but here is the product from toytech
  5. May 28, 2009 at 6:24 AM
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    Good morning,
    I see that another gentleman replied to you and he is correct....
    Toyotec does offer an AAl that will lift the rear and it will be right around
    the 1 1/2" mark as far as lift....After you install the AAL along with the TSB you already have done...I would get a ride height measurement from mount to mount with the truck sitting there under its own weight...Just to be on the safe side...Most likely the stock shocks will be to short at full droop and you will need to run an aftermarket shock that has a little longer collapsed and extended dimesion by about 1.75" at full extension and around 3/4" to 1" at a collapsed length....
    Let me know if there is anything that we can help you with....
    Thank you,
    Sonny
  6. May 28, 2009 at 6:34 AM
    laperlanegra
    Deb
    Vista, CA
    Since I purchased the front 5100s from you, Sonny, do you have any recommendations for the rear shocks? Also, do you sell them? Once I get all the parts, do you have a local shop in SD that you recommend? Thank you very much for the info, much appreciated.
  7. May 28, 2009 at 9:28 AM
    Lakeside, Ca. 92040
    Good morning,
    Yes the Bilstein 5100 series rear shocks...BE5-C476-H0 or the RCD part #
    BE5-C478-T0 will both work in the rear with up to 1.5" of lift....
    I see that you are located in Oceanside?????
    Let me know when you have a chance and I might have someone
    I can refer you to in North County....
    Thank you,
    Sonny
  8. Jun 5, 2009 at 10:36 AM
    laperlanegra
    Deb
    Vista, CA
    thank you sonny. i'll contact you when i'm ready to buy and then get the shop recommendation at that time.
  9. Jul 20, 2009 at 6:55 AM
    laperlanegra
    Deb
    Vista, CA
    hi sonny,
    i'm ready to get those 5100's for the rear. what is the cost? can we do paypal? also, do you have any shop recommendations in the north county? i still need to order the toytec aal tsb.
    thanks a bunch.
  10. Jul 21, 2009 at 7:04 AM
    Lakeside, Ca. 92040
    Good morning,
    PM me and I will get you the price on the rears and
    the name of the shop in NC....
    Thank you,
    Sonny
