need reccomendation for a good extended shock (1st gen)
Discussion in 'Suspension' started by fireturk41, Nov 7, 2010.
  1. Nov 7, 2010 at 9:41 PM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    okay, i am almost done with my taco build and just have to find tires, replace a clock spring bud built belly pan, and shocks. I took off the old OE ones in the rear because they were maxed out at ride height, i bought some big black cocks from poly performance and behold at 15 inches they are too big, they are the same size as my front ones but they have no uptravel. im wondering what most of you guys would reccomend for the rear of a truck with an aproximate of 5 inches of lift. I have Bilstein 5125's in the front but cant find any in the same size for a decent price atleast not in the size i need according to 4wp.
    so what would yall reccomend? if yall are vendors or have a link to where yall got them post it :) im so excited to get the taco back in service
  2. Nov 8, 2010 at 4:01 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    morning bump?
  3. Nov 8, 2010 at 12:20 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    bump bump bump bum bump
  4. Nov 8, 2010 at 2:18 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    so no reccomendations?
  5. Nov 8, 2010 at 3:35 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Seems like you need to figure out exactly how much shock travel you have on each side. Saying you have about 5" of lift does not tell the whole picture.
    When the suspension is fully extended, what is the exact distance between the top shock mount and the bottom shock mount? How does that compare to when the suspension if full compressed? If you do these two measurements, you'll be able to calculate the third set of info you need. The difference between the two (extended and compressed) measurements will tell you the total travel.
    Now you need to do the same measurements on the other side becasue they will not be the same. Here is a great article that describes all this much better than I can.
    http://www.bajataco.com/travel-measurement.html
    Once you have the 6 sets of numbers you can order the shocks you need from someplace like DownSouth Motersports.
