Need recommendation for a place to press off/on rear axle bearings in Phoenix
Discussion in 'Arizona' started by PHXtaco04, Feb 12, 2015.
  1. Feb 12, 2015 at 9:02 PM
    PHXtaco04
    PHXtaco04 [OP] Member
    Craig
    Phoenix, AZ
    04 Dbl Cab 4X4
    2004 4dr V6, ICON coil overs and rear shocks, Camburg arms, manual hubs, Deaver springs in the rear. Light Racing Jounce Shock System (Front & Rear) Demello rock sliders and rear bumper. Bud Built IFS Skidplate and Belly Skidplate. BFG 33X10.5 tires. ARB bumper and Warn XD 9000 On board air. CB, in dash moving map, ScanGauge II gauge. IPT Valve Body Upgrade
    Just pulled the driver rear axle shaft and the bearing isshot. The truck is a 2004 Tacoma and has the ABS ring on the axel shaft thatwill have to be pressed as well. Can anyone recommend a shop in the Phoenixarea I can bring the shaft in to have the bearing replaced—either with orwithout me bringing in the new parts?
    Thanks!
  2. Feb 13, 2015 at 6:45 PM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    I can't help you much, I took mine to the Toyota dealer.
  3. Feb 17, 2015 at 4:54 PM
    PHXtaco04
    Craig
    Phoenix, AZ
    04 Dbl Cab 4X4
    I called the Toyota dealer service department, and with me bringing the axle shaft in the door (i.e. off the truck), my out the door price, including parts, was $531.00
    I went ahead and ordered the tools I needed to press it ($415.00) and OEM parts online ($65.00 + S&H) and still came out ahead. While I am sure I could get it done for a lot less than the dealership, the couple shops I checked did not have the right tools (the jig for the press), and ultimately, I figured the other side will need the bearing replaced shortly and I have a 2nd Tacoma that is a daily driver that will likely be needing the bearing replaced in the near future too, so I might as well have the tools needed to do it.
    I found my receipt from the last time I had the bearings replace (in California). It was in 2009 and only 85,000 miles ago. The bearings were Napa bearings rather than Toyota, and the cost to do BOTH sides including parts & labor was $314.00.
  4. Feb 17, 2015 at 5:02 PM
    PHXtaco04
    Craig
    Phoenix, AZ
    04 Dbl Cab 4X4
    And for anyone on here in the Phoenix area who stumbles across this thread because they are needing to replace the rear wheel bearing on their Tacoma, feel free to shoot me a PM as I now have the jig as well as the press to do the job. Actually the jig is advertised to work on early Toyota pickups 1975 - 1995, as well as 4 Runners 1984 - 2011, Tacoma 1995 - 2011, T-100's 1993 - 1998, Tundra 2000 - 2012 and Sequoia 2001 - 2008, FJ 2007 - 2012, Lexus GX 460 2010-2011, Lexus GX470 2003-2009 and Tacoma Pre-Runner 2005 -2011. This tool also works on most Nissan, Mitsubishi, and Isuzu models that have the backing plate that interferes with normal pressing.
  5. Feb 17, 2015 at 6:49 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    thanks, i'll track this thread for whenever my rear bearings go out.
  6. Feb 17, 2015 at 7:24 PM
    Buckoma
    Buckeye, AZ
    2016 TRD Sport 4x4
    Heh... I was going to say I'll have to hit you up as a joke, then I read the last post. Count on it!
    By the way, I was checking out your website maybe 7-8 years ago(?) when I was first starting to look into Tacoma adventure travel online. You and the BajaTaco were early inspirations... although I never really did much to my own truck.
