Need Recommendations for new(used) truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by newertoy, Feb 27, 2010.
  1. Feb 27, 2010 at 1:49 PM
    newertoy
    newertoy [OP] Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Hello To All,
    Currently searching for another Toyota truck. Have a 1991 w/many miles and figure it is time for a newer version. Do not off road, but do go into the woods occasionally for fire wood and seclusion. Of course it will need to be 4x4,extened cab,manual tranny. Looking at years 2003-2007. 4x4 is a must and will not do any regular towing. Whats the deal w/4x4 and no shift lever??? Auto hubs too( that does not look good).
    Any and ALL information is appreciated.My OLD Truck is getting tired and cannot take the abuse much longer
    Thanks to All,
    Kevin
  2. Feb 27, 2010 at 1:57 PM
    Reznor88
    Reznor88 Well-Known Member
    Northern California
    '06 PreRunner DC Off Road
    Welcome to TW.
    You say 2003-2007, so do you not care what generation Tacoma it is or do you just not know the differences?
    2005 and newer are going to be your 2nd gens while anything prior to 2005 are your older style 1st gens.
  3. Feb 27, 2010 at 1:58 PM
    trib
    trib Well-Known Member
    My ideal tacoma for back country excursions would be an '05 or '06 4d 4x4 short bed with a 2in suspension lift. Same wheel base as the extra cab but more room when camping and hauling passengers. Plus they look better imo with shells than access cabs.
  4. Feb 27, 2010 at 1:58 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    What do you mean "what's the deal" ? The only truck I know of that still has manual locking hubs is the Ford SuperDuty.What exactly do you want to know?
  5. Feb 27, 2010 at 2:28 PM
    matt86
    matt86 Well-Known Member
    NC
    2008 Tacoma SR5 4x4
    It depends on what you're looking for. The 2003 and 2004 Tacomas are smaller than the 2005-2010 Tacomas so they may be better for excursions in the woods. It may be worth a TRD Offroad package if you're going to be in the woods alone so that way you'll have a locker to help you get through the nasty stuff.
    Personally I like my 2010 Tacoma and am partial to this body style.
  6. Feb 27, 2010 at 3:11 PM
    MocoTaco
    MocoTaco Active Member
    USA
    07 Taco reg cab 4cyl., AT, 5 lug
    Access cab 2nd gen Taco is the way to go. Love the 1st gen too but newer usually have less miles. :D
    The new locking hubs are actually easier, flip a switch inside on the go if 4hi, stop for 4lo flippit & go again.:rolleyes:
  7. Feb 27, 2010 at 3:45 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Thanks for all the FAST info!! Are there any reliability issues that I should consider or know about? i have had No normal wear problems w/ the 91. Replaced the tranny only because the syncronizers were WORN out. Actually due to my own stupidity towing too heavy of a load. LIVE & LEARN!!!
  8. Feb 27, 2010 at 4:45 PM
    trib
    Lots of people seem to be complaining about the build quality of their '09s and '10s on this board. My pre-runner is an '05 and built in Fremont. My buddy has the exact same build as me but in white. I have 60k on mine so far, my buddy has 40k. We've both never had a single problem except our mud flaps broke off. Not a big enough deal for me to cry about. We have loaded the crap out of these things each summer camping (see avatar) where we'd hit bottom going over small speed bumps and no issues. Hopefully these trucks will last to 200k.
  9. Feb 27, 2010 at 5:18 PM
    HankB
    HankB Well-Known Member
    Hank
    near Chicago
    06 Preruner TRD Off Road
    bone stock
    One thing that comes to mind if you plan to haul fire wood. The factory leaf springs in the US are 3 leaf and tend to bottom out easily with a loaded truck. There is a TSB to replace these with 4 leaf rear springs to reduce this problem but if you purchase a truck out of warranty, cost is prohibitive. There are other solutions and if you are planning to lift, perhaps this is not an issue. (I haven't looked into lift so I simply don't know.) There might be some used trucks that have the 4 leaf rear springs already installed and these are standard in Canada.
