need rim size to match my tires w/o lift...
Discussion in 'Wheels & Tires' started by rbeezy, Jan 28, 2012.
  1. Jan 28, 2012 at 3:20 AM
    rbeezy
    rbeezy [OP] Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    Ok so i searched but havent found the answer i'm looking for, unless i didnt try hard enough, but going thru 10 pages is good enough... so I have some Firestone Destinations 265 75 16's and want XD Bully rims but without the lift. Guy at the shop said these particular rims wont fit, but others on here have these rims.....
    so my question is, what size rim do i need without a lift and i dont want any rubbing issues... i believe its 16x8? just not sure about backspacing and offset. HELP!
  2. Jan 28, 2012 at 3:24 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    16x8 and 265/75r16 is what I'm running now, though the backspacing is what you'd need to look at; sure you dont have those numbers?
  3. Jan 28, 2012 at 3:35 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    First, they are wheels, not rims.
    Like Kona said, you need to know the backspacing or offset of the wheels to know for certain. There are instructions for measuring the BS here.
  4. Jan 28, 2012 at 3:49 AM
    rbeezy
    Ron
    Bay Area
    2011 Tacoma SR5
    there are different sizes i found for a 16x8. the one i think might work is a 4.5" bs with 0 offset?? will that work?
  5. Jan 28, 2012 at 3:51 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    that will work IIRC
  6. Jan 28, 2012 at 3:55 AM
    JDMcQ
    I agree with the pineapple.
  7. Jan 28, 2012 at 3:57 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Cause that's the same offset/BS that I'm running now...no problems here
  8. Jan 28, 2012 at 4:51 AM
    rbeezy
    Ron
    Bay Area
    2011 Tacoma SR5
    so we have the same size tires and you have no lift also? no rubbing issues right? just want to make sure before i move forward with the "wheels" lol (no pun intended)
  9. Jan 29, 2012 at 10:26 AM
    rbeezy
    Ron
    Bay Area
    2011 Tacoma SR5
    so the 4.5" bs should be okay then huh? is stock rims a 16 x 8?
