Need shop suggestion/recommendation for A/C work in Anchorage
Discussion in 'Alaska' started by fergyz, Jul 30, 2018.
  1. Jul 30, 2018 at 3:28 PM
    fergyz
    fergyz [OP] Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    I will be doing a complete A/C system overhaul on my truck. I will personally replace all the components. The system is complete dry at this time. I don't have access to a proper machine to finish the work. not looking to buy the equipment either I am looking for a shop that can service the system with a vacuum, fill refrigerant, and won't cost an arm and a leg.
    I assume i will be charged an hour of labor plus the R-134a at a minimum.
    Any suggestions?
  2. Aug 2, 2018 at 9:08 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    TBD
    I don't, but let me know what you find. My system is dry right now as well and it would be nice to have it filled again.
  3. Aug 2, 2018 at 9:17 AM
    SJC3081
    SJC3081 Well-Known Member
    Wappinger NY
    2011 DCLB 4x4
    Fill it yourself. Walmart sells R134 kits with a pressure gauge. YouTube for guidance. I would spend $40 and top off A/C before I replaced any parts.
  4. Aug 17, 2018 at 12:58 PM
    fergyz
    49th State
    06' DBC 4x4 6spd
    i found out the oreilly's had a vacuum pump that i was able to rent. not all the stores have them so you will need to check around. the one on Dowling did. they didn't have the manifold gauge for rent. i was told they were going to order one, but didn't.
