Need Size on A/C Evaporator drain hose 94 pkup
Discussion in 'Toyota Trucks & SUVs' started by Sbpd50816, Jun 18, 2013.
  1. Sbpd50816
    Sbpd50816 [OP] Active Member
    Jeremy
    Corona Ca
    2012 Double Cab..Trd Sport..Metallic Grey
    Stock
    Hey guys I had water leaking all over my passenger floor board, I traced it down to the plastic nipple on back of the evaporator housing. Directly across from it is a hole into the firewall with a grommet around it. There is no hose going from the nipple to outside the firewall to drain the water so its just dripping down the firewall onto my floor board on the passenger side. Does anyone know the part # or size of oem hose that is suppose to be used for that ?
