Need smother start from neutral to first?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TeamRooR, Mar 22, 2010.
  1. Mar 22, 2010 at 6:32 AM
    TeamRooR
    TeamRooR [OP] Well-Known Member
    Phil
    Hedgesville, WV
    2003 Tacoma TRD 4x4
    K&N intake, rust
    As I stated in a previous post I just picked up an 03 trd tacoma, have driven it for about 1000 miles so far, it has a total of 61k on it. I have had 2, 4 cylinders in the past and am finding this v6 a bit different to drive.
    I am finding it hard to make smooth start in first gear in this new truck, I have to hit the "sweet spot" just right when releasing the clutch in order to get a smooth transfer from neutral to moving in first gear. It catches just fine, but would really like it to be a smoother transition, any ideas?? I have driven many manual transmissions some a little harder then others but have never had to do any adjustments in the past so I am a little clueless on how to go about making the transition from neutral to moving in first a little smoother.
    Any ideas would be appreciated.
  2. Mar 22, 2010 at 6:40 AM
    takern
    takern Well-Known Member
    Tanner
    Virginia
    03 TRD Offroad stepside
    Deckplate mod, sliders, uniden cb, toolbox, dakar leaf pack, in search of coilovers, 255/85 16 bfg m/t waiting to go on
    let out the clutch a bit slower? the clutches on these trucks take some getting used to i found out
  3. Mar 22, 2010 at 6:45 AM
    TeamRooR
    Phil
    Hedgesville, WV
    2003 Tacoma TRD 4x4
    K&N intake, rust
    Guess it just takes some getting used too??
    It is just not as smooth as my past vehicles so I thought maybe something needed tuned/adjusted.
  4. Mar 22, 2010 at 6:57 AM
    saweetlou
    saweetlou Well-Known Member
    Guelph Ontario
    TRD Stepside
    2in Skyjacker
    Before I start I usually rev up and let the clutch out on the wind down of the revs and accelerate from there.
  5. Mar 22, 2010 at 7:00 AM
    TeamRooR
    Phil
    Hedgesville, WV
    2003 Tacoma TRD 4x4
    K&N intake, rust
    just checked the clutch master cylinder and it is pretty dirty, have never done anything with them before not sure if that could improve anything??
    I will research that a little?
  6. Mar 22, 2010 at 7:00 AM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    What's happening when you start? If it's stuttering, it could maybe be suspension related, not your shifting technique. When i first got my 01, it would kind of shutter/bounce when I started from a dead stop, and I thought it was just me and/or the engine. I upgraded the rear suspension to Alcan springs and that stutter went away, it was the suspension winding up and snapping back.
  7. Mar 22, 2010 at 7:06 AM
    TeamRooR
    Phil
    Hedgesville, WV
    2003 Tacoma TRD 4x4
    K&N intake, rust
    Just my opinion, but I don't think it is suspension related.
  8. Mar 22, 2010 at 7:29 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    Bilstein 5100 CO's @ 1.75" - Icon UCA's - TSB Rear w/Bilstein 5100's - Air Lift System - Flowmaster 50 Duals(RIP...back to stock for now) - Avid Offroad Arctic Bar - Avid Offroad Nerf Bars - Leer 550 Bedcover - AVS Hood Protector(RIP) - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    The clutch reservoir should be drained and cleaned regularly. I did it with each oil change. All that black crap settles in the lines and eventually kills the clutch master cylinder.
  9. Mar 22, 2010 at 7:42 AM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    depending on what clutch is in there it may be a rough engaging clutch
    IE stage 2 or 3 6 puck etc
  10. Mar 22, 2010 at 8:47 AM
    TeamRooR
    Phil
    Hedgesville, WV
    2003 Tacoma TRD 4x4
    K&N intake, rust
    I plan on doing that when I get home from work this evening. know any good how to's on cleaning it out?
  11. Mar 22, 2010 at 9:22 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    The clutch on mine can engage roughly at times, mostly when cold. I let it out until it begins to catch, then add just enough gas for it to not stall while letting it out the rest of the way. This will help extend your clutch life but isn't as smooth of a start as reving it up first (which only burns up your clutch).
  12. Mar 22, 2010 at 9:37 AM
    bb609
    bb609 O.F.
    NH
    Pretty simple. Pick up one of these at any pharmacy.
    Remove the cap and suck out the fluid with the syringe. Wipe the remaining crap out of the reservoir and refill with Dot3 (???????????? It's been a while) brake fluid. Keep an eye on it as the black stuff will start to work back out of the line so you'll want to change it every couple hundred miles for a while. Hopefully, your clutch will start working a bit better. Mine did.
    X2 on the type of clutch it may be also. Could be aftermarket which may grab quicker.
  13. Mar 22, 2010 at 9:41 AM
    TeamRooR
    Phil
    Hedgesville, WV
    2003 Tacoma TRD 4x4
    K&N intake, rust
    without sounding like a jerk, I know how to drive a standard.
    What I am saying is that I would not want to sit in rush hour bumper to bumper traffic with the way it currently starts off in first. It has to get better then what it is. It is not utterly terrible, just not as easy to drive as my previous Tacoma's so i am assuming something needs to be tuned or fixed.
  14. Mar 22, 2010 at 9:44 AM
    TeamRooR
    Phil
    Hedgesville, WV
    2003 Tacoma TRD 4x4
    K&N intake, rust
    Question, do I suck the reservoir bone dry, then wipe it out? Should I be worried about getting air in the line that way??
  15. Mar 22, 2010 at 11:36 AM
    bb609
    bb609 O.F.
    NH
    Don't try to drain the line :p but yes, wipe it out clean...gently.:)
  16. Mar 22, 2010 at 11:42 AM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    maybe the previous owner burnt the clutch? I put in a brand new clutch in my 03 when the previous one was slipping, and it worked prefectly. Then I burnt it pretty bad trying to pull my buddies jeep out of some mud, and now my car shakes a little on takeoff...
  17. Mar 22, 2010 at 1:11 PM
    TeamRooR
    Phil
    Hedgesville, WV
    2003 Tacoma TRD 4x4
    K&N intake, rust
    Well Guys... Thank you all for your suggestions.
    I went out and just gravity bleed the slave cylinder for about 20-30 minutes, kept filling it up as it drained out. I would stop, shut off the bleeder and pump the clutch a bunch of times then start again. I stopped when it was clean.
    I just drove it around for about 0.5 mile start and stop and it could be mental but I am fairly certain it made a difference, just a much smoother transition. I will report back if my mind was just playing tricks on me...
    **UPDATE**
    NIGHT AND DAY DIFFERENCE!! GOES INTO GEAR A HECK OF A LOT SMOOTHER NOW TOO.
