Need Some Advice For A Piece That Fell Off
Discussion in '1st Gen. Tacomas (1995-2004)' started by boyer, Apr 19, 2011.
  1. Apr 19, 2011 at 7:46 AM
    boyer
    boyer [OP] Member
    Josh
    Perry County PA
    2005 Tacoma 4x4 6-Speed TRD Sport
    ARB Front Bull Guard - 1006$ UWS Diamond Plate Tool Box
    2003 Toyota Tacoma
    Access Cab / V6 / SR5 / 5Spd / TRD / BLK
    Well,
    Long story short I was stuck in a mud hole. I had to get pulled out which took some time. Well there was some damage but minimal. I broke my right rear tail light. Which BTW if anyone knows where to get one for cheap please let me know. But aside from that, when I was finally out I went to survey the damage. I looked underneath the front of the truck and noticed what looked to be a big piece of plastic or aluminum hanging down under the truck. It was right under where the engine is and behind the factory skid plate. I have been trying to figure out what piece this is called. I do not have it anymore since it fell off on the ride back. Any help is appreciated.
  2. Apr 19, 2011 at 7:55 AM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    ive got a pair of factory tail lights that are in great shape id sell you and take a pic of the location the part fell off of so ive got an idea of what it was.
  3. Apr 19, 2011 at 9:00 AM
    boyer
    boyer [OP] Member
    Josh
    Perry County PA
    Here is a pic.
  4. Apr 19, 2011 at 9:12 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    I'm betting it was a heat shield off of one of the cats
  5. Apr 19, 2011 at 9:17 AM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    Im pretty sure that is the second skid plate... You have a front big one and then a front small one that is directly behind it based off the picture that is what it looks like to me
  6. Apr 19, 2011 at 9:25 AM
    98tacoma27
    Ben
    Not Beech Creek
    X2. The factory skid is two pieces.
  7. Apr 19, 2011 at 9:26 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    Hmm could be. maybe the trd trucks have an extra one that my sr5 doesn't
  8. Apr 19, 2011 at 9:29 AM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    well for one 1st and 2nd gens differ, plus the smaller skid protects the front diff and partial driveshaft components, you are a 2wd good sir:p
  9. Apr 19, 2011 at 9:29 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    A 2nd gen has a different skid then a 1st gen.
  10. Apr 19, 2011 at 9:47 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    yes, that looks like the second skid plate.
  11. Apr 19, 2011 at 9:50 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    ohhh didnt realize it wasa first gen:eek:
  12. Apr 19, 2011 at 10:06 AM
    boyer
    boyer [OP] Member
    Josh
    Perry County PA
    Cool,
    Is there anywhere in particular to buy just the second skid plate? Or a better alternative?
  13. Apr 19, 2011 at 10:14 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Before you buy another one you should make sure the bolts that were holding it on didn't get broken off in the nuts or something, inhibiting your ability of bolting another one on. Time for some cleaning and further investigation...
  14. Apr 19, 2011 at 10:38 AM
    boyer
    boyer [OP] Member
    Josh
    Perry County PA
    Well, A quick look shows some rusting on the current skid plate where it bolts on. Truck is clean now.
  15. Apr 19, 2011 at 11:02 AM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    my advice would be to invest in aftermarket like allpro of budbuilt skid plates, they are heavier duty than stock skids and you shouldnt run into this problem again..... also stay out of the mud if you can, having a skid plate torn off will be the least of your worries if you keep doing it
  16. Apr 19, 2011 at 12:29 PM
    tacomaforlife
    Robbie
    AIKEN, SC
