Need some advice on age old leveling question…
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dhoock, May 3, 2022.
  1. May 3, 2022 at 10:39 AM
    dhoock
    dhoock [OP] New Member
    Dillon
    2015 Tacoma Double Cab 4x4
    Stock
    Howdy! Basically, after some great advice from the folks here I am opting for leveling my 2015 4x4 double cab long bed (140k Mike’s) with the bilstein 5100s on the front. Possibly coils in the future depending on the ride quality. I don’t do any serious off-roading or haul much, just some mountain trips. I don’t want any bro lean.. if I set the front at 1.75, would that get me level?
    Next question.. in the future I would like to put Bilstein 5100s on the back. Would putting the rear 5100s on the rear give me any rear lift at all? Would it be best to do an AAL with the rear 5100s? My concern with the rear is ride quality and vibration. I would only like to add about 1-1.5 inches back there once I have the money after the front bilstein purchase. I’ve seen a lot of folks getting the blocks for the rear, but that can have some negative implications down the road right? I don’t want to go a cheap route just to hurt my truck long term.
  2. May 3, 2022 at 10:43 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    1.75 in front might level it out but as soon as you put a bucket of tools in the back the dreaded bro lean will appear.
    Just replacing shocks in the back won't affect ride height, that's up to the springs
    Just do a AAL out back, set the Bilsteins how you like, it'll ride fine
  3. May 3, 2022 at 11:45 AM
    dhoock
    Dillon
    Stock
  4. May 3, 2022 at 5:22 PM
    JCzerosixtaco
    JCzerosixtaco Well-Known Member
    KY
    2006 SUPER WHITE ACLB MT, TRD OR, TP, SR5
    Total stereo replacement, TRD Exhaust, Fox 2.0 coilovers, 2.0 reservoirs with an AAL in rear for about 2.5 inch lift, gunmetal TRD 4Runner wheels wrapped in K02
    Yeah they can handle 0-1” of lift without being destroyed from over extension
  5. May 3, 2022 at 5:25 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Don't level. You want rake. At least 1". You will always sag in the back if you level over time and when anything is loaded.
    Clearwater Bill likes this.
  6. May 3, 2022 at 7:16 PM
    dhoock
    Dillon
    Stock
    Meaning I can put up to a 1 inch block or AAL with those shocks or the shocks can be raised an inch?
  7. May 4, 2022 at 4:45 AM
    JCzerosixtaco
    KY
    Yes. An AAL on the other hand will raise the ride height of your truck much more than a 1” block because it’s helping support some weight off your factory leaf pack. But the actual increase in suspension travel or droop will b just the thickness of the aal itself. Those 5100’s will work just fine in either case.
