Need some advice on detail
Discussion in 'Detailing' started by Twiostaco, Aug 10, 2011.
  1. Aug 10, 2011 at 8:04 AM
    Twiostaco
    Twiostaco [OP] Well-Known Member
    Austin
    Utah
    08 White DC TRD Sport
    5100's front set to .85 w/eibach springs, 5100 rear w/toytec 2"AAL, Light Race UCA, 17" Black Rhino Ocotillo wheels, 265/70/17 KO2's, K&N drop in filter, Grill Craft front mesh, one piece driveshaft (vibes gone) rear diff breather mod, BHLM, Fog anytime, 886 reverse bulbs.
    Ok so I am planning on doing a nice detail to my paint this weekend and need some help. I have some trail pin stripes from some branches that I want to remove I am thinking meguires scratch x for this? I also want to clay bar the entire truck. In which order should this done? scratch-x or clay bar first? Also do I need to polish and wax or just wax? And do you think i can do this all by hand or would I be better off getting a buffer?
  2. Aug 10, 2011 at 10:13 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    Clay first. Then you can use scratch-x if you'd like. Dont bother with a buffer if you're just using scratch-x. Finish off w/ a wax.
  3. Aug 11, 2011 at 8:57 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    Wash, clay, polish, wax.
    A buffer does a better job and is easier than doing it by hand, but there is increased risk, depending on what buffer you choose. Orbital buffers are safe but less effective than rotaries. Rotaries are more effective but there is increased risk of taking off too much paint. A forced rotation random orbital lies somewhere in between. But they are expensive.
    There are probably dozens of threads out there discussing the pros and cons of both. There are die-hard Porter-Cable users that swear its the best tool for the job, while others wouldn't be caught dead using a Porter-Cable.
    I have two rotaries and a forced-rotation random orbital. I use the rotaries for aggressive work and the forced rotation random orbital for finesse work. I almost never polish by hand.
    If you are going to use a rotary, you absolutely need to train first. At a bare minimum, practice on a vehicle's whose paint you wouldn't mind trashing before you touch anything else.
  4. Aug 11, 2011 at 5:29 PM
    Twiostaco
    Austin
    Utah
    Ok thanks for the info so wash, clay, scratchx, do I have to polish or just wax? Looks like this will be done by hand
  5. Aug 11, 2011 at 8:01 PM
    Gooch
    Orange County CA
    Using the scratch-x is polishing and you should always follow up with wax.
  6. Aug 12, 2011 at 6:01 AM
    Twiostaco
    Austin
    Utah
    Ooooohhhh OK. So is it ok of I'm just using the scratch x on the sides? I'm just trying to get rid of the branch scratches. So I wasn't gonna do the hood or the roof or tailgate.
  7. Aug 13, 2011 at 7:05 PM
    Gooch
    Orange County CA
    Yeah, that's fine. As a general rule, only polish where you need to as it removes paint.
  8. Sep 6, 2011 at 8:38 PM
    shoebag22
    shoebag22 Well-Known Member
    Is there any harm in skipping the polish step?
    wash->clay->rewash->wax?
  9. Sep 7, 2011 at 7:59 AM
    Gooch
    Orange County CA
    No harm, except claying usually leaves fine scratches. Depending on the paint color though, you may not notice it.
    White and silver are pretty forgiving, but black and other dark colors show the scratches easily.
  10. Sep 7, 2011 at 1:36 PM
    shoebag22
    Gotcha... is there any point in polishing by hand or is it futile?
  11. Sep 7, 2011 at 2:19 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Its exhausting and wont yield the same results. If you're doing it by hand, I'd recommend using a paint cleaner, like P21s' cleansing lotion.
  12. Sep 7, 2011 at 5:33 PM
    Gooch
    Orange County CA
    I agree, but the subject usually invokes a 'Ford versus Chevy' type of debate that I try to steer clear of.
    I almost always polish with a buffer, unless I'm spot repairing something quick, usually on a vehicle that someone isn't overly concerned with (they just want the blemish gone).
