Need some advice on intermittent brake problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by 99 tacomaguy, Aug 13, 2016.
  1. Aug 13, 2016 at 4:07 PM
    99 tacomaguy
    99 tacomaguy [OP] New Member
    99 tacoma 200,000 miles 4WD
    OME 2 inch lift
    I need the wisdom of the board here. Sometimes when you press on the brake it seems very hard, and then it gives and seems normal. It just started happening when I hit around 200,000 miles and happens intermittently. It will work fine for a few weeks then go through a period of random stiff braking. I don't hear any noise. The brakes act normal when the power is off, and most of the time, but it is getting more common. The truck has non abs brakes. does anyone have suggestions on where i should start? Is so, i would really appreciate it. The truck is in great shape and i am hoping to keep it on the road a while.
    Thanks!
    Dave
  2. Aug 13, 2016 at 4:11 PM
    Clearwater Bill
    Billy
    Largo Florida
    Check the booster check valve, check valve grommet, and the hose from the check valve to the engine.
    Sounds like you don't always have boost. Always start checking with the simple stuff and keep your fingers crossed!
  3. Aug 13, 2016 at 4:13 PM
    99 tacomaguy
    OME 2 inch lift
    Thanks, Bill. I will try it and update the board with the results.
  4. Aug 13, 2016 at 4:32 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Yep, stiff brakes usually point to the brake booster.
  5. Aug 13, 2016 at 4:43 PM
    motorpool98
    motorpool98 Member
    Keith
    1999 Tacoma Pre-Runner V-6
    2 3/4 exhaust flow master muffler and a new air freshner
    I agree about the brake booster but before you replace it check the vacuum hose for leaks.
  6. Aug 13, 2016 at 5:47 PM
    Clearwater Bill
    Billy
    Largo Florida
    Check post #2 :p
  7. Aug 13, 2016 at 5:59 PM
    motorpool98
    motorpool98 Member
    Keith
    Sorry I'm not trying to take away your glory here just missed your comment about the hose is all. Can you find it in your heart to forgive me? :sorry:
  8. Aug 25, 2016 at 4:15 PM
    Clearwater Bill
    Billy
    Largo Florida
  9. Aug 25, 2016 at 8:07 PM
    99 tacomaguy
    OME 2 inch lift
    update.. .
    After my initial post, the problem got a lot more frequent, it was acting up multiple times daily(I drive about 80 miles a day) I decided to start at the beginning so I bled all the brakes/new fluid throughout. It was at night so I did not check anything else at the time. Next day no problem. I have put 500 miles on it since and only have experienced a "hint" of the initial hard braking a couple times. I probably only noticed it since I am waiting on it, but I think it is still there but minimized with the bleed/new fluid. I will keep driving it and see what happens. The old fluid was a little darker than the new but did not look too bad. I will let you guys know if there is any change, appreciate the help.
