Need some advice - rodent damage
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Omegastu, Sep 10, 2024.
  1. Sep 11, 2024 at 5:36 PM
    Odlcjro01
    Odlcjro01 Well-Known Member
    Lee
    Rhode Island
    2021 Tacoma MGM DBC SR5
    LT265/75R16 tire, side steps
    We had the same problem with wife Corolla. Once fixed I got mouse blockers and have them in the engine bay for her car and my truck. Nothing has come back yet.
  2. Sep 12, 2024 at 4:32 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    That or Bounce dryer sheets are a popular choice with the boat guys during winter storage. I tried using the store brand dryer sheets one year and the mice made a nest under one of the seats in our pontoon. I went back to genuine Bounce brand and never had an issue again.
    Stuck in VT likes this.
  3. Sep 12, 2024 at 4:40 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
  4. Sep 12, 2024 at 5:57 AM
    mattm55
    mattm55 Well-Known Member
    Mid-Hudson Valley, NY
    2017 BBPearl Tacoma TRD Sport Access/AT w/SnoWay
    I tried bounce sheets, peppermint sachels, pepermint oil, antifreeze cocktails, sticky traps, snap traps, mouse blocker w/lights and sound... can't remember what else.
    The best thing I read was once they nest and piss, you have to steam clean it or they just come back. I have snap traps and caught 2 mice so far while all that other stuff was going on so in my case, the other crap isn't working. :facepalm:
    jmneill likes this.
  5. Sep 12, 2024 at 6:25 AM
    cropduster78
    cropduster78 Well-Known Member
    NW CT
    '17 DCLB SR5 White
    OV-TUNE 2.0, ADDED/REMOVED STUFF
    I've said it on here before the best mouse trap I've found is a 5 gallon bucket filled with a gallon of molasses.
    Hit up Tractor Supply for everything.
    Basically a mouse tar pit....set it and forget it. You'll be surprised at the results.
    mattm55 and atc250r like this.
  6. Sep 12, 2024 at 6:49 AM
    sailor_lou
    sailor_lou Active Member
    Lou
    NH
    2023 Access Cab TRD OR
    I had similar problems with a motorhome in our last house and the all the mentioned fixes (soap, dryer sheets, mothballs, peppermint oil, etc) did not work. I ended up building a barrier around the entire rig using 12" aluminum flashing. I made a removable gate to get in and out. The critters either couldn't climb the smooth surface or just didn't try, but after removing and repairing the generator twice and finding mouse dropping all over the rig it was worth the effort. When we moved, we build a large RV garage first and then the house. Obviously the best fix, but expensive. Good luck.
  7. Sep 12, 2024 at 5:56 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    Mouse blockers? Details, what brand, links?
  8. Sep 12, 2024 at 6:01 PM
    Odlcjro01
    Lee
    Rhode Island
    There are allot of options. I chose they as I was having a hard time getting the one that attaches to the battery to work on Corolla. Loraffe Under Hood Rodent Repeller Battery Operated Ultrasonic Car Rat Repellent Mice Deterrent Keep Animal Away from Car Vehicle Protection, 2 Pack https://www.amazon.com/dp/B07N6JZ2J4
    atc250r likes this.
  9. Sep 28, 2024 at 10:35 AM
    Omegastu
    Omegastu [OP] Well-Known Member
    Mid Tenn
    2021 Cement TRD Sport DCSB
    Happy-ish ending to the story. Took 3 weeks to get fixed but damage was much less than expected. About 2 grand total. In the mean time, I have killed 5 squirrels and turning a couple of barn cats into trained assassins. Also dousing the engine bay with a peppermint spray as a deterrent.
  10. Sep 28, 2024 at 12:30 PM
    Ainapo
    Ainapo Well-Known Member
    SW WI
    MT+LB=sport
    After mice chewed my harness the second time, I bought a roll of Honda rodent tape and had the tech wrap the new wires. So far, so good.
    Sometimes I keep a packet of cab fresh on top of the cabin air filter. Mice like to chew it up and use it as nesting material.
  11. Sep 28, 2024 at 1:09 PM
    Williston
    Williston Unknown Member
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    There actually is a solution that could be adapted or modified for automotive use. Mice chewed the propane hoses to the main burners, the side burner and hose from the tank on my Weber gas grille. I came across just by chance of a round metal spiral/coil spring produce that you slide over the length of the rubber hoses. Picture a "Slinky" that is a little bigger diameter than the hoses. It stretches enough to cover the entire length of the hose and has enough spring in it so that it will stretch out to both ends and stay in place. No evidence that mice have ever chewed it and it doesn't rust. Search: "Propane Hose Safety Guard" on Amazon
    I'm sure this would work in the engine compartment, but it would have to be installed at the factory before the connectors were installed on the harnesses.
  12. Sep 28, 2024 at 1:34 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    check out Mouse Trap Mondays on youtube
    I've been thinking about building a plank style trap in a 90+ gallon trash can
    atc250r likes this.
  13. Sep 29, 2024 at 10:01 AM
    atc250r
    Orange County, NY
    90 gallon!! :eek:
  14. Sep 29, 2024 at 10:28 AM
    CraigF
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    that's the rough size of the large trash/recycling 2 wheeled cans
    entrance hole about 2/3 up on the front for the plank and an eye bolt across from it for the bait
    fill about 1/3 with water for drowning
    maybe a hasp on the lid to keep looky loos out
  15. Sep 29, 2024 at 11:15 AM
    #35
    atc250r
    Orange County, NY
    How big of a rodent problem are you battling?
  16. Sep 30, 2024 at 7:11 AM
    #36
    Omegastu
    Mid Tenn
    They are pretty sure my issue was caused by squirrels. I've been training my 12 lb schnauzer to get after them. Like I said, we got two barn cats. Also shooting as many as I can find. Shotgun too loud for daily use, 22 same, BB gun not enough power (although I did kill one with a BB last week), so I am thinking about a more powerful air rifle. I work at home, so I can open the window and shoot at them between meetings.
  17. Sep 30, 2024 at 7:19 AM
    #37
    atc250r
    Orange County, NY
    Omegastu[OP] likes this.
  18. Sep 30, 2024 at 7:59 AM
    #38
    Aikidoka69
    Aikidoka69 Well-Known Member
    Denver, CO
    2020 TRD Off-Road 6MT
    Now now, vehicle manufacturers say there is no evidence soy based wiring is more attractive and they would never lie to protect their bottom line....
    I had this issue repeatedly with an A4. You almost could not even park it outside a single night. Turned out to be rabbits. Catch one and relocate and another would take its place. I left one at my daughter's daycare after it apparently came along for the ride. Audi would put a metal sheathing over the targeting wires after it was hit the second time. When I inquired why I had to pay them twice to address it properly, they did it the second time at no cost. No problems since I swapped the A4 for the Tacoma. Not sure why they are not interested in the Escape. Might just be the design of the plastic plate underneath the A4 made it very appealing. The peppermint spray did not help really.
    atc250r likes this.
  19. Sep 30, 2024 at 12:44 PM
    #39
    Omegastu
    Mid Tenn
    I had a rabbit crawl into my Silverado one time when I lived up in Virginia. Truck started but radio didn't work. I popped the hood and looked down in there, turned my head to the right and had a full size rabbit about 2 inches from my face. He didn't do too much damage, just chewed up the power wire to my amp.
  20. Sep 30, 2024 at 2:47 PM
    #40
    saltybum
    saltybum Well-Known Member
    Bob
    Space Coast
    2022 Tacoma Access
    Wabbits is goooood eatn'.
