Need some advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lilyoda707, Jun 5, 2019.
  1. Jun 5, 2019 at 12:51 PM
    lilyoda707
    lilyoda707 [OP] Active Member
    2011 trd sport
    I recently changed my oil in my 2011 Tacoma... today I noticed after slowing down to take a turn, once I was through the turn and went to press on the gas it seemed to not want to go. Like the rpm jumped up to 2-3 and then it kind of kicked. So I took it back home and checked the oil level and it seemed really really high. Like an inch past the max full. So I'm draining my oil out and am going to put some back in. I dumped 5 quarts of oil in the first oil change but only about half came out... what's going on? Does any one have any suggestions of what might be wrong?
  2. Jun 5, 2019 at 12:52 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Don’t be offended, but are you sure you drained engine oil and not the tranny?
  3. Jun 5, 2019 at 12:55 PM
    lilyoda707
    2011 trd sport
    Yeah I’m positive I drained the oil. This isn’t the first oil change I’ve done on it, but I can’t help but feel like an idiot for not being able to figure this out.
    Steves104x4 likes this.
  4. Jun 5, 2019 at 12:55 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Uh-oh. So when you originally drained the oil, only about 3 quarts came out? And you went home and drained more and only about 3 quarts came out? That sounds like transmission fluid.
    Blockhead likes this.
  5. Jun 5, 2019 at 12:56 PM
    lilyoda707
    2011 trd sport
    The truck is parked on a level surface and I took the oil fill cap off and drain plug out and I’m just letting it drain out of the engine but it seems like nothing is coming out.
  6. Jun 5, 2019 at 12:57 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Post a picture of the oil pan.
  7. Jun 5, 2019 at 12:59 PM
    98tacoma27
    Ben
    Not Beech Creek
    It does sound like you've emptied the transmission and refilled the motor.
    Drunken Chewbacca likes this.
  8. Jun 5, 2019 at 12:59 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    What does the dip stick show after you drain the engine oil? If its still shows full, I would side with the transmission fluid theory.
    98tacoma27 likes this.
  9. Jun 5, 2019 at 12:59 PM
    tcjacado
    tcjacado Well-Known Member
    :popcorn:
    What color was the fluid??
  10. Jun 5, 2019 at 1:00 PM
    98tacoma27
    Ben
    Not Beech Creek
  11. Jun 5, 2019 at 1:03 PM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    The part of the oil pan for the engine oil drain plug is real small and the low part of the trans pan is about twice the length. Engine oil drain is near the front of the engine and the trans is right behind the rear of tge engine. Easily mistaken for the engine oil pan :anonymous:
  12. Jun 5, 2019 at 1:03 PM
    lilyoda707
    2011 trd sport
  13. Jun 5, 2019 at 1:04 PM
    lilyoda707
    2011 trd sport
    I’m a dumbass... how can I fix this. Y’all are right I drained the tranny
  14. Jun 5, 2019 at 1:04 PM
    tcjacado
    :eek:
  15. Jun 5, 2019 at 1:04 PM
    CouchlessPotato
    Zach
    2.5" lift w/35's
    I've been there lol. Hopefully you can just fill the trans back up and be good to go.
    Kolunatic, Gunshot-6A and tcjacado like this.
  16. Jun 5, 2019 at 1:05 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Whoah now, don't fret. If you haven't driven it a long way, everything is probably just fine. Just need to add tranny fluid and get your oil level right.
    Kolunatic and Gunshot-6A like this.
  17. Jun 5, 2019 at 1:05 PM
    rnish
    Tacoma 2nd gen
    Please do not drive the truck until the transmission fluid level has been remedied.
  18. Jun 5, 2019 at 1:09 PM
    lilyoda707
    2011 trd sport
    Alright I haven’t driven far at all. Like 2 miles total. I’m gunna drain the oil and get that right and take another car to get some transmission fluid. Where do I fill the tranny back up? Just so I don’t fuck this up again.
    Kolunatic likes this.
  19. Jun 5, 2019 at 1:09 PM
    Blockhead
    Pittsburgh, Pa.
    Don’t panic.
    There’s a thread on here on how to fill the tranny, follow it closely. If you’re unable to or not confident with your abilities you’ll need to get it towed to a shop you trust and have it done.
    Also, find the engine oil plug and drain it completely, then put in 5.5 quarts.
  20. Jun 5, 2019 at 1:09 PM
    tcjacado
