Need some advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lilyoda707, Jun 5, 2019.
  1. Jun 5, 2019 at 1:10 PM
    lilyoda707
    lilyoda707 [OP] Active Member
    2011 trd sport
    Blockhead can you link that thread or point me in the right direction please? I’m not very familiar with the site
  2. Jun 5, 2019 at 1:10 PM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    Yes you did this
  3. Jun 5, 2019 at 1:10 PM
    lilyoda707
    2011 trd sport
    Thank you guys and gals
  4. Jun 5, 2019 at 1:15 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
  5. Jun 5, 2019 at 1:17 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
  6. Jun 5, 2019 at 1:21 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Kolunatic likes this.
  7. Jun 5, 2019 at 1:22 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    PS. Filling an automatic transmission on a 2nd gen requires the fluid being at the proper temperature. This is a somewhat involved process. As an emergency measure; if you know how much “Transmission” fluid you drained can fill it back up with an equal amount. This should be considered a bandage until you can get the truck to shop or you can get the transmission up to proper temperature and thus level.
    Also Toyota WS Transmission fluid is expensive. I and a lot of people use Valvoline MaxLife. Use at your own risk, YMMV. It runs about $18 per gallon at Walmart.
  8. Jun 5, 2019 at 1:22 PM
    Blockhead
    Pittsburgh, Pa.
    Not to rub salt in the wound but I’m curious, do you remember what you did when you changed the oil a while back? I’m guessing you didn’t drain the transmission that time.
  9. Jun 5, 2019 at 1:27 PM
    lilyoda707
    2011 trd sport
    Haha yeah I know I did it right last time, as I changed it right before I drove across the country. As soon as I saw the picture posted of where the oil pan was I realized you all were right. I guess I was just distracted this time around. Obviously I should have been *more* positive about saying that haha
  10. Jun 5, 2019 at 1:27 PM
    rnish
    Tacoma 2nd gen
    Was alcohol involved?
  11. Jun 5, 2019 at 1:28 PM
    Blockhead
    Pittsburgh, Pa.
    It happens, you should be fine...good luck
  12. Jun 5, 2019 at 1:35 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    :popcorn:
  13. Jun 5, 2019 at 1:38 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Youll be fine OP. Lots of dudes on here have done this.
  14. Jun 5, 2019 at 1:40 PM
    Ev_trdtaco
    Ev_trdtaco Well-Known Member
    Everett
    Colorado Springs, CO
    2018 Tacoma TRD Offroad
    King Shocks Total Chaos Upper Control Arms OME Dakar HD Leafs BFG KM3s 285/75r16 SCS F5s 16x8 4.5bs Wheelers Super Bumps and U Bolt Flip Kit Mobtown Offroad Rock Sliders W/Kickout RCI Bed Rack CVT Mt. Shasta Summit Series Roof Top Tent RCI Full Skids Tacoma OEM Bed Mat TRD Pro Grill Husky X-Act Contour Floor Liners
    Sounds like this thread should be in the 3rd gen forum
    wheeliest likes this.
  15. Jun 5, 2019 at 1:43 PM
    #35
    98tacoma27
    Ben
    Not Beech Creek
    Just make sure you use the right fluid on the refill.
  16. Jun 5, 2019 at 1:46 PM
    #36
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Did that once with my wife's Subaru. :anonymous:
  17. Jun 5, 2019 at 2:00 PM
    #37
    Gingerbeard Man
    Gingerbeard Man Well-Known Member
    Jared
    North Dallas
    2016 MGM DCSB Sport 4x4
    Icon stage 3 tubular 285/70/17 Toyo ATII
    Lmao
  18. Jun 5, 2019 at 2:02 PM
    #38
    Muddinfun
    Muddinfun Well-Known Member
  19. Jun 5, 2019 at 2:04 PM
    #39
    Shelf Life
    Rob
    Central Oregon
    Pssshhh. Everybody knows that's where the windshield washer fluid goes.
    Muddinfun[QUOTED] likes this.
  20. Jun 5, 2019 at 2:05 PM
    #40
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    The transmission being slightly overfilled or slightly underfilled, while not ideal, is not a big deal. Usually you'll get about 3.5 quarts out of the pan on a drain. However, if you drove it and drained again, not sure how much would come out the second time around (I'm not clear if you tried a second drain or not).
    Get the right fluid, Valvoline MaxLife or Castrol makes one as well, just make sure it is the right kind.
    If you only did the one drain, start with 3.5 quarts and get it up to temp. If you did a second drain, you'll have to guess how much came out, but probably another 2-3 quarts or so. You likely did not drain more than about 7 quarts, so having 8 quarts, or 2 gallons on hand would be prudent.
    Using an IR thermometer should get you close enough if you can't get it into temp mode (lots of folks have difficulty, I have a Scangauge that I use but probably more expensive than an IR thermometer, and you have to program it to read the right sensor). Just add 2 or 3 degrees to the IR reading -- someone on here did a test, the difference between the sensor reading and the IR reading was only about 2 degrees. Do the trickle procedure and be happy that you now have some fresh tranny fluid in there!
