"Need some boat ramp advice"
Discussion in 'General Automotive' started by Jay28, Feb 8, 2012.
  1. Feb 8, 2012 at 3:30 PM
    Jay28
    Jay28 [OP] New Member
    Jay
    panama city
    06 Prerunner 2X4,5-speed
    My 06 2.7 I-4 motor pulls my 3000 pound boat just fine. The problem is the stupid boat ramp. I either burn out on the open diff or slowly let out on first gear of the 5-speed and burn some clutch. The tires and rims that came with the truck are bigger and wider than the stock rims that did come with the truck. I feel stuck. I am not sure to buy some smaller tires and put the stock rims back on and spend about $600.00 or buy a ARB locker. Any feedback would be helpful.
  2. Feb 8, 2012 at 3:31 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    hmm... have you tried putting weight in the bed of your truck or airing down?
  3. Feb 8, 2012 at 3:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Weight in the bed, and you might want to consider an LS diff.
  4. Feb 8, 2012 at 3:32 PM
    Blasphemous
    Blasphemous Well-Known Member
    San Fernando Valley, CA
    2012 TRD Sport DC 4x4
    TRD SC, Stealth Pulley, DTLT Headers, URD MK3 Catback Exhaust, AFE II Intake
    x2
  5. Feb 9, 2012 at 6:19 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Here's where the manual kind of hurts you, with an auto, you can apply a bit of brake as you apply gas and that acts like a "poor mans LSD". I would guess that you could try that with the manual, but chances are you'd already be spinning by the time you moved your foot from the clutch to the brake. If you can work two pedals with one foot, this might be something to try.
  6. Feb 9, 2012 at 3:22 PM
    Jay28
    Jay
    panama city
    I will try to air down the tires this weekend and see how that goes. Wish me luck :)
  7. Feb 9, 2012 at 3:27 PM
    97yota4wd
    Eric
    Mesa, AZ
    grab a couple sand bags and throw them in the bed, or throw people back there when pulling out
  8. Feb 9, 2012 at 3:34 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    You can do this with the ebrake since it's a pull handle on the manual transmissions.
    I think you're gonna have to slip the clutch even though it sucks to since you don't have the low end torque that the v6's have. Or buy a 4x4.
  9. Feb 9, 2012 at 4:13 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    ^^^^this I did this with an old 2x4 4cyl works good. takes practice
  10. Feb 14, 2012 at 11:25 AM
    Jay28
    Jay
    panama city
    I went to a ramp and just practiced(with out the boat) working with the e-brake, seems I needed it. My first couple of trys I was humbled. My fourth pull from the ramp I had learned right where I need to have things. I also got a heavy rubber chalk with a chain on it. If the truck wants to roll back at all it wont. The chain is to pull it out after I have cleared the momentum barrier. Last weekend I stayed home because of the cold conditions. This weekend there might be rain. Thank you all for the advice.:D
  11. Feb 14, 2012 at 11:41 AM
    macgyver
    Brad
    Canton, GA
    Practice makes perfect ^^^
    I use my ebrake on boat ramps so that I don't roll back when starting off and have to slip the clutch a lot.
  12. Feb 15, 2012 at 12:19 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Anyone notice this in the bst or is it just me?
  13. Feb 15, 2012 at 12:40 PM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    Nope, I noticed it too. lol
