Need some Guidance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TIMMAAY, Jan 18, 2012.
  1. Jan 18, 2012 at 5:10 PM
    TIMMAAY
    TIMMAAY [OP] Member
    Tim
    Crofton
    2011 Tacoma 4x4 4door short bed brush gaurd
    brush gaurd, running boards, tint, TRD off road pkg.,
    got me a 2011 Taco trd with the stock wheels and tires currently. I want to do a 3 inch lift, I dont do much off roading, But I like the look and this is my new hobby. I have two questions 1) When you install a 3" lift do you need to make your drive line longer? and 2) what is the max diameter tire can be installed without having to do any cutting or trimming? Any input relevant to these questions would be awesome. Thanks.
  2. Jan 18, 2012 at 5:14 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I'll say it before anyone else does, use the search function on the website, it will help you out a lot and allow you to find exactly what you're looking for! Welcome to TW
  3. Jan 18, 2012 at 5:16 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Hi Tim,
    Welcome to the party!
    No need to get a longer drive line.
    I would try and stay under 34" tires to minimize rubbing issues.
  4. Jan 18, 2012 at 5:22 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    As far as lifts go.......you can go spaced or coilover. Is spend the extra for the coilover lift. OME makes awesome kits. Or you could always go 5100's with your stock springs.
  5. Jan 18, 2012 at 5:26 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You don't need to extend the length of your drive line. Max size tire you can run without trimming is 265/70R17 or I believe 265/75R16. There are some other oddball sizes people have experimented with also but that is probably the most common.
    Check out Downsouth Motorsports, Toytec Lifts or Wheelers Offroad for lift ideas. As stated above, you can either go with a spacer lift or a coilover set-up. Depends on your budget and intended.
  6. Jan 18, 2012 at 5:37 PM
    rcbs204
    I run 275/65/18s, and the only rubbing i have are in reverse, or when there are 4 big guys in the truck, and i full lock. Of course this pavement only. Off-road, i have definite issues with rubbing on the cab mounts.
  7. Jan 18, 2012 at 7:52 PM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    265/75/R16s will not rub. At least they don't on mine. A full 3 in lift with new ucas and proper backspacing on your wheels would allow 285s but may require some trimming to prevent rubbing. I've heard both ways. Some rub, some don't.
  8. Jan 19, 2012 at 2:22 PM
    TIMMAAY
    TIMMAAY [OP] Member
    Tim
    Crofton
    Thank you all for the insight. The combined wealth of experience available here really helps new enthusiasts to make smart decisions, only so many dollars available so I gotta make 'em count. Thank you all again and when I finally get over my aversion to spending I will take photos and post them. I would like to receive input and guidance on future mods. Cool.:bowdown:
  9. Jan 19, 2012 at 3:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    youve got questions....weve got answers....usually.:D
