Need some guidance...
Discussion in 'New Members' started by Brian 0blivi0n, Jul 6, 2022.
  1. Jul 6, 2022 at 10:37 AM
    Brian 0blivi0n
    Brian 0blivi0n [OP] Well-Known Member
    Wisconsin
    2018 TRD OR
    Alright, as title states I need a little guidance. Bought a '18 Off Road last fall for a great price. The only downside is it has a spacer lift and I feel like its contributing to a very stiff ride. Every bump feels like the rear end is slamming down. I love the look of the lift, but hate the ride. My question is what suspension upgrades should I look into while maintaining the front rake look that I have? The Tacoma is my daily driver and I do very light trail riding...mostly during hunting season. Also looking to get a tent in the future.
    I have read several threads regarding Blisteins, Dobinsons, and Ironman's kits but I am just so confused on what would fit my needs.
    I know there probably have been countless threads on this, but any guidance or help for a newbie would be greatly appreciated.
  2. Jul 6, 2022 at 10:44 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    How many miles are on the truck? I'd recommend you put 350 lbs in the back of the truck and see if (and how much) the ride improves (not as a permanent solution but just to get an idea of where the problem resides.)
    It looks like you have the stock Goodyear Kevlar tires so the tires aren't the problem (adding heavy truck tires can make for a shaitty empty ride.)
    Is this your first truck? I ask because these trucks completely unloaded don't ride like a car.. I'm not sure how much you have to spend to make it have a car-like ride.. obviously more than $1650 (as that's what I've spent). My truck rides best loaded with at least 500 lbs.. empty it's firm and rides like a truck.
    Anyone recognize those front spacers?
  3. Jul 6, 2022 at 10:48 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Welcome to TW. Great looking truck.
    Lots of different options really and as long as you’re moving away from a spacer lift you’ll be good. Lots of people here have had great experiences with Ironman, Eibach, OME, Billies and other expensive kits.
    Maybe @memario1214 can let you know what they sell most of and that’ll give you a start. I’ve got IM and am happy with my kit. It is stiff though when paired with E rated tires.
    Brian 0blivi0n[OP] likes this.
  4. Jul 6, 2022 at 10:50 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Spacer lifts do ride rough.
    I'd go with bilstein 5100 shocks and a 3 leaf add a leaf. That should cost roughly $800 in parts. Then install yourself or find someone to install. Will ride much better than the spacer lift you have.
  5. Jul 6, 2022 at 11:06 AM
    Brian 0blivi0n
    Wisconsin
    2018 TRD OR
    There were 14,000 miles on the truck when I bought it and I just doubled it. I've had mid size and full size trucks in the past.
    I am fine with the truck ride, but to me the rear end is just jarringly stiff when going over larger bumps...like nothing is getting absorbed. I contributed it to the spacer lift, but I also haven't had very much weight in the back yet. I have some cash to spend, but doubt I'd ever make use of some of the more expensive kits. I'm essentially just looking for an upgrade over the spacer lift that will retain the look of the truck I have now.
    I've had my eye on the OMEs. But kind of confused on the customization.
    Gen3TacomaOBX[QUOTED] likes this.
  6. Jul 6, 2022 at 11:34 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    How are the leaf springs? Are you bottoming out on the bump stop? from the pictures you got a lot of lift.
    FloridaFree likes this.
  7. Jul 6, 2022 at 12:35 PM
    Gen3TacomaOBX
    S
    Ok, cool. Then I'd agree with @Superdave1.0 :
    1. Headstrong progressive AAL (without the overload)
    https://www.headstrongoffroad.com/store/p1239/HS_1.5"_lift_3_leaf_AAL_with_u-bolts_(PAIR)_-_HS-TOY516-3AL.html
    2. Upgraded Bilstein rear shocks.
    Many are very happy with 5100s in the rear. You have a choice of standard or extended length. I'd go with extended.
    Standard: https://www.headstrongoffroad.com/store/p463/Bilstein_5100_Standard_Length_Rear_Shock_(PAIR)_-_24-186728_for_2016__Toyota_Tacoma.html
    Extended: https://www.headstrongoffroad.com/store/p86/RCD/Bilstein_5100_Extended_Length_Rear_Shock_(PAIR)_-_B110.html
    If you don't mind spending another ~$300 then you have an option to go w/fancy reservoir shocks.
    https://www.headstrongoffroad.com/store/p84/Bilstein_5160_Rear_Shock_with_Reservoir_(PAIR)_-_05__Tacoma.html
    Edit: Of course you can buy from any of the reputable online retailers. There are other progressive AAL available but I believe Headstrong is one of the more popular here on TW. I linked to Headstrong as that's where I sourced my suspension.
  8. Jul 6, 2022 at 1:51 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    Black DOG Lila likes this.
  9. Jul 6, 2022 at 1:54 PM
    FloridaFree
    FloridaFree Well-Known Member
    TRD OffRoad 4x4 mgm
    OME 887 with nitro chargers, icon add a leaf ECGS bearing former 886
    I was thinking maybe he is missing a leaf from the prior owner installing the block lift
  10. Jul 6, 2022 at 5:48 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
  11. Jul 6, 2022 at 11:04 PM
    .357bang
    .357bang Sharpshooter Jerry
    Jerry
    AZ
    You are welcome to TW
