Need Some Help After Jackstand Failure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by superskaterxes, May 27, 2015.
  1. May 27, 2015 at 3:39 AM
    superskaterxes
    superskaterxes [OP] Active Member
    Hey guys and gals,
    i had some fail this weekend when i was going to plastidip my wheels. I had the truck up on 3 TON jackstands with all of the wheels off and between the slight slope of my driveway and the soft asphalt underneath, one of my jackstands collapsed and the rear of the truck fell onto the ground.
    Somehow the pumpkin did not crack and everything looked ok but now my dash looks like a christmas tree. My ABS, BRAKE, and car with squiggley lines lights are on and im not sure why. The truck drives fine with no clunks or anything so im looking for a little help in figuring out that this is. I think i remember this happening to a different car of mine when one of my wheel speed sensors broke but those are mounted high up on the drums so im not sure how they could have gotten damaged. Has anyone ever had this happen before?
    -TIA
    Picts of fail and WIN
  2. May 27, 2015 at 3:47 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Check the wire that goes across the top of the axle, I bet its cut or broke.
  3. May 27, 2015 at 3:49 AM
    koditten
    Kirk
    Central Michigan
    Glad no one got hurt. I don't believe that is a jack stand failure. No JS is designed to work on a slope.
  4. May 27, 2015 at 3:57 AM
    superskaterxes
    its a very light curve in the driveway and i believe the corner of the stand started to sink into the hot asphalt which was ultimately what lead it to fail.
  5. May 27, 2015 at 4:08 AM
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    Sounds like a damaged abs sensor to me.
    Glad you weren't under it when it happened. And yeah don't ever put a vehicle up on jack stands on any kind of slope. Also if you're on soft asphalt a small square of plywood under the stand will keep it from sinking in.
  6. May 27, 2015 at 4:09 AM
    superskaterxes
    would a scan tool that can check ABS codes be able to tell me?
  7. May 27, 2015 at 4:11 AM
    JBecker
    Virginia
    Yeah it should be throwing a code. But I bet it's pretty obvious if you look at the side that fell. Either the wires got pinched or the sensor itself got crushed.
  8. May 27, 2015 at 4:11 AM
    glock24
    glock24 Well-Known Member
    Thanks for posting. All of us could use a little safety reminder now and again.
    Glad you weren't injured
  9. May 27, 2015 at 4:15 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The scary part is...............I have the same exact jack stands.
    superskaterxes[OP] likes this.
  10. May 27, 2015 at 4:18 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    But you won't ever use them on a hill
  11. May 27, 2015 at 4:26 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    You'd be surprised what I'm capable of.
    I applaud the OP for posting this. He might just save someones life.
    mtnceej, Chipskip and DrFunker like this.
  12. May 27, 2015 at 4:40 AM
    superskaterxes
    you guys keep saying this was on a "hill" but you would be surprised how slight the incline was. If you look at the truck picture in the OP, it was even less sloped then the top of the driveway where the truck is parked. Just goes to show you how careful you must be. Im no idiot and ive had jacks fail on me in the past which is why i always use jackstands but this was a real eye opener for me.
  13. May 27, 2015 at 4:46 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Scary stuff for sure. Hope you figure out your issue OP.
  14. May 27, 2015 at 4:50 AM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    That's definitely a 10%+ slope.
    Regardless glad no one got hurt, truck can be fixed.
  15. May 27, 2015 at 5:17 AM
    2000TRDTaco
    2000TRDTaco Well-Known Member
    Corey
    Angier, NC
    00 Prerunner
    Jackstands on asphalt are dangerous....I personally always try to use them on concrete
  16. May 27, 2015 at 5:19 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I'm so paranoid about cars falling on me that I used two jacks, two jack stands, and ramps when I put a Magnaflow exhaust on my Audi.
    T4RFTMFW and SMHdavid like this.
  17. May 27, 2015 at 5:22 AM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    Same here - I usually throw the tires under the frame so just in case it comes down it doesn't come down all the way (if tires have to be removed of course) or keep the jack as a back up
    TaylorU and Arailt like this.
  18. May 27, 2015 at 5:23 AM
    JBecker
    Virginia
    This is why I like a truck. I don't have to put it on jack stands or a lift to do many things under the truck. I love cars, but I hate having to jack them up to do anything, like change the oil filter.
  19. May 27, 2015 at 5:24 AM
    TacomaMike37
    13' DCLB MGM
    Nah, no chance that is 10%, much less alone >10%. 10% is STEEP , you will know right away when you are looking at a 10% slope.
  20. May 27, 2015 at 5:27 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Wow, scary. Been using jack stands, well since the dinosaurs were alive. Never had one fail. Knocked my '83 mud truck off the stands once, never a failure. No on the asphalt, yes on the ply wood under the stand. Something is going on if this has happened before, be careful and alert, for death is under there with you if things go very wrong.
    Scary.
