Need some help here
Discussion in 'Wheels & Tires' started by torunakasone, Oct 17, 2008.
  1. Oct 17, 2008 at 1:13 PM
    torunakasone
    torunakasone [OP] Member
    808-STATE
    08 Prerunner TRD Sport BLACK SAND PEARL
    ICON COIL OVERS-TOTAL CHAOS UCA-T-REX BILLET GRILLE-TRD CAI-FLOW MASTER- 50-TINT-OEM TUBE STEPS-IN CHANNEL VENT-DEBADGED-BHLM-AFTER MARKET TAILS-
    I was wondering if anyone can help me.........I have a stock 08 TRD Sport Prerunner What is the largest tire I can put on some Dick Cepek DC-1 17x9 rims with 4.53 inch backset. My stock tires are 265x65R17,my rims are 17x7.5. stock tires are too narrow for my new rims.......I do not want to lift or modify my front end............Thank you in advance for your Help.........
  2. Oct 17, 2008 at 1:27 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    In general the rule of thumb is you can go 2" wider or narrower with the tire than the rim. I would suggest you find the tires you want, they should have the specs of the tire along with what rim widths the tire is made for. Just find the one that suits your rims. You should be able to go with a 265/70/17 that would be 31.6" tall.
  3. Oct 17, 2008 at 1:37 PM
    torunakasone
    808-STATE
    Luk8272........so I shouldn't have any rubbing with the 31.6 tall tires? How wide can I go without rubbing........Thanks for your reply.........
  4. Oct 17, 2008 at 2:02 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
  5. Oct 17, 2008 at 2:03 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    This site is good for just punching in the numbers and seeing how tall they will be and how it will change your speed.
  6. Oct 17, 2008 at 2:05 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    yeah, i ran 265-70-17 on my 17x9's with 5" BS and 0 offset and they rubbed the front mudflaps a little when turning, not enough to cause damage, just enough to annoy me until i got the lift on. your stock tires should fit too....
  7. Oct 17, 2008 at 2:17 PM
    torunakasone
    808-STATE
    Thanks again Luk8272
    Thank you Xtreme450 both of you have been very helpful..............
  8. Oct 17, 2008 at 2:25 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Thats what we are here for, to shar our experiences.
