Need some help Leaf Packs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoNooch, Nov 16, 2024.
  1. Nov 16, 2024 at 2:35 PM
    TacoNooch
    TacoNooch [OP] Member
    DA
    2020 Tacoma OR
    1.5 lift front 1 inch rear. SPC UCA’s
    Need a little help selecting leafs packs. So I recently did the 5100 adjustable with the new Falken At4. My truck sits nice however I notice a slight sag in the rear. I still have stock leafs. I see a lot of leaf packs that add height. Is there a leaf pack thats just stronger and wouldnt add any lift?
  2. Nov 16, 2024 at 4:14 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    What do you mean by stronger?
  3. Nov 16, 2024 at 5:54 PM
    TacoNooch
    DA
    2020 Tacoma OR
    Somthing better than the stock I have in there which will help against sag but not add lift. If that make sense
  4. Nov 16, 2024 at 6:29 PM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    Roadmaster active suspension
  5. Nov 16, 2024 at 6:33 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    As mentioned the RAS could be a good option for you otherwise if I remember correctly General Springs makes a minimal to no lift set of springs
    TacoManOne likes this.
  6. Nov 16, 2024 at 7:01 PM
    Taudelta
    Taudelta Well-Known Member
    Iurii
    South Florida
    2023 Tacoma Trd OR
    Steelcraft Fortis front bumper, BodyArmor 4x4 rear bumper, LIft: Bilstein 5100+2885 OME coils, Icon RXT 3 stage. 255/85/16 wildpeak at4w
    rxt icon, you can choose different settings, i set em at 3rd stage because of heavy rear bumper and more equipment to install in nearest future, but you also need to lift front. you can buy ome springs and install em in front
    if you dont need lift just use the 1(defualt setting) on rxt
  7. Nov 16, 2024 at 7:39 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    option 1 rxts have less load capacity than stock and will still add lift which he doesn't want
    Taudelta[QUOTED] likes this.
  8. Nov 16, 2024 at 7:42 PM
    devinzz1
    devin
    2023 aclb trd or mt
    it sounds like you want to add lift.? if your rear is "sagging" with no extra weight in the bed. then yeah just get an add a leaf. multi leaf packs for no extra weight. single leaf aal for running extra weight
  9. Nov 16, 2024 at 7:42 PM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    Alcan springs can accommodate your needs.
  10. Nov 16, 2024 at 7:58 PM
    Taudelta
    Iurii
    South Florida
    2023 Tacoma Trd OR
    i tried AAL 1.5" icon - with additional 100lbs weight of rear bumper it went down for 1".
    you are right about small lift with 1 setting rxt icon, my bad. but i believe it will go down with small weight or settling process
  11. Nov 17, 2024 at 7:08 AM
    Dorf510
    Dorf510 Well-Known Member
    Tyler
    Vista, CA
    18 TRD 4x4
    Dayton wires, flux-capacitor, port-a-potty
    OP- save your time and just order a new leaf pack. The factory leafs sag with a cooler in the bed, and the RXT or any “ADD a Leaf” are temp fixes, they will sag themselves within a year(ask me how i know). Alcan makes some good factory height springs, deaver stage 1 are also very nice too(provides 1.5in lift). All depends on bed weight(accessories and gear) and intended usage.
    LOLLY likes this.
  12. Nov 17, 2024 at 8:07 AM
    TacoNooch
    DA
    2020 Tacoma OR
    Thank you all for your help
  13. Nov 17, 2024 at 8:31 AM
    gudujarlson
    Minnesota
    How do you define the words “better”, “sag”, and “lift”?
    Are you saying you want a leaf pack with a higher spring rate (stiffer) that will maintain stock ride height when not loaded? If so, I’m not aware of a such a product on the market, but I know you can have custom leaf packs made by Alcan.
    https://www.alcanspring.com
    Note that "better" is in the eye of the beholder. A stiffer spring like the one I described above will tend to decrease the ride quality. If the ability to carry more weight is more important than ride quality, then such a spring is "better", otherwise it might not be.
    Personally, I have leaf springs that are similar in stiffness to the stock springs, but provide about 2" of added ride height (lift). For me this is "better". I wanted more clearance without sacrificing ride quality.
    LOLLY likes this.
