Need some help... Not running right
Discussion in '3rd Gen. Tacomas (2016-2023)' started by InfTacoCV, May 28, 2024.
  1. May 28, 2024 at 1:45 PM
    InfTacoCV
    InfTacoCV [OP] Member
    2016 TRD Sport V6 Manual
    Truck is basically stock except up one tire size and OTT in January. Current 86k miles. Oil change is about due and air filter was changed at OTT . Will be due for plugs and all fluids changed soon
    About 6 weeks ago I noticed this happening. It does not do it all the time but recently has gotten a little more frequent.
    When I take off and shift into second the truck sometimes just falls on its face and kicks bucks then snaps out of it and accelerates fine. I have tried to see about what the RPMs are when I shift from 1st to 2nd and its in the neighborhood of 2500-3000. Doesn't matter the air temp outside. Doesn't matter if I let truck warm up first or start and go. Although it seems a little more frequent when engine is not fully up to temp.
    2nd issue is it has backfired twice. Not loud. When making a turn or driving in a roundabout as I come out in 3rd gear and start to accelerate is when it has happened. Only has done it twice. But basically the truck just fell on its face kicked and bucked and backfired. Ive tried downshift to 2nd and accelerating out of the corner but RPMs are way to high and traffic stacks up behind me. 3rd is the obviously the correct gear and the RPM is around 3000-3500 when I start to accelerate and the issue happens.
    Im not hauling anything and truck is empty except for me and gas. No lights have ever come on so I have not had it scanned. I didn't know if scanner would reveal anything since no codes have been thrown yet.
    It acts almost like a fuel filter in need of replacement but its totally sporadic and I may go days before it does it again. All the other times truck runs great ive owned since I bought it with 43 original miles. With previous vehicles I have owned when a fuel filter is plugged its a consistent issue until replacemed. I don't think its the fuel filter and I am only aware of the truck having one in the tank.
    Oh and it doesn't matter which way I turn and accelerate when it happens. Some have been left turn then accelerate and some right. Roundabouts of course are mostly a left turn
    Thanks for any help
  2. May 28, 2024 at 1:48 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    2026?? Marty, is that you?
    Pedal issue?
  3. May 28, 2024 at 1:50 PM
    InfTacoCV
    Oops typo 2016 I will fix it. No not Marty my name is Earl, for real lol
  4. May 28, 2024 at 1:57 PM
    InfTacoCV
    Pedal was set to Mild with the OTT. It ran great after the OTT in January and this didn't start until March maybe April. I spoke to the tuner who offered to scan it its just we are having scheduling issues on getting together. I agreed with him that if it ran perfect up to April the tune is likely not the cause. Computer codes just don't change on their own unless acted on by a virus or malware. How would that have happened when its not an open network system
  5. May 28, 2024 at 2:49 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Retune it to stock and see what happens.
    joba27n, Stevie17 and hiPSI like this.
  6. May 28, 2024 at 4:29 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yep.
    shakerhood, joba27n and Stevie17 like this.
  7. May 29, 2024 at 6:15 PM
    JohnDeere630
    JohnDeere630 Well-Known Member
    Gary
    Gray 2023 Tacoma SR5
    My 2008 2.7L did the exact same thing. It was an ignition coil on the #3 cylinder.
    soundman98 likes this.
  8. May 29, 2024 at 6:29 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I think your plugs were due at 60k miles. I would get those replaced. A good scanner can see misfires happening live. Sometimes you can have a cylinder misfiring and not throw a CEL. Agree with the others, flash back to stock for now.
    shakerhood likes this.
  9. May 29, 2024 at 6:34 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Ya, ask your tuner to look for codes anyways. Drivability codes should throw on the light but it's possibly one is pending and the concern is just not happening frequently enough to actually set the code and light. It's also not a bad idea to change the plugs if you were planning to but otherwise see if you two can go for a drive and monitor the misfire counter to see if you can narrow it down to a cylinder.
    You could also try cleaning your throttle body and maf to see if that changes things.
    Outside of that I would try to either reflash the tune or return to stock for a bit and see where that gets you. Update us when you find out what the cause is
  10. May 29, 2024 at 6:45 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    this is my suspicion as well. plugs might be a little old if they're original, but won't be causing the issues as much. those generally result in a unstable/rough idle as they age.
  11. May 29, 2024 at 7:09 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Have you had the fuel pump recall done? Your 2016 is covered for 10 years regardless of mileage.
    https://static.nhtsa.gov/odi/tsbs/2023/MC-10236191-9999.pdf
