Need some help on a carpentry project.
Discussion in 'Garage / Workshop' started by hendooman, Jun 14, 2011.
  1. Jun 14, 2011 at 9:16 AM
    hendooman
    hendooman [OP] The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    I am building a shed in my backyard and I have gotten to a point where I am struggling to get the right angle on my rafters. I am building a simple gable roof with a 8" overhang with a standard plumb cut. The shed is 96" wide outside edge to outside edge. I want a 5/12 pitch on the roof and will be using a standard 2 x 6 as the ridge beam.
    I am struggling with the birdsmouth cuts and the ridge rise. The depth and dimensions throws me all off. I am going to use 2 x 4's as rafters since it is just a shed and will be plenty strong for my needs. Does anyone have a program or the knowledge to fill in the blanks on these dimensions.
    Let me know if I am missing any needed measurements. Thanks and hope someone can help.
  2. Jun 14, 2011 at 9:19 AM
    hendooman
    Jeff
    KC
    Shed so far...
  3. Jun 14, 2011 at 9:21 AM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    Check with OZ-T. He is a carpentry ninja.
    Alternatively, it as all geometry calculations for triangles. If you know the height and width (the L part of the triangle), you can determine the length of the hypotenuse (the longest side(s) fotht triangle, your rafter length). Google geometry (or carpentry) calculators, and you should be off and running. Once you have all three sides, you can calculate all angles.
    To determine roof pitch, you can look up recommended pitches and work from there, too.
  4. Jun 14, 2011 at 9:28 AM
    hendooman
    Jeff
    KC
    I thought about simulating the the ridge beam. I can get that done. But is there a trick to getting the birdsmouth right? I can always trial and error. If I dont have exact dims by this weekend I will do that method. Just thinking I could get dims, and cut all the rafters at once and knock it out real quick.
    OZ-T where are you???
  5. Jun 14, 2011 at 9:31 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    oh ozzy oz where are you?!
  6. Jun 14, 2011 at 9:31 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    North DFW
    07 DCSB Sport 2wd
    5100s @ 0.85, Grom iPod/Bluetooth adapter, mud flaps removed, clear turn signal bulbs, two extra D-rings, debadged, fog light anytime, OEM bed mat, Undercover classic, Falken Wildpeak A/T3W, Fumoto valve
  7. Jun 14, 2011 at 9:34 AM
    hendooman
    Jeff
    KC
    I think that gets me close...would the angle of the heel cut be the same as the end plumb cut?
    Here's what I got from that site:
    Overall Rafter Length: 4 ft 11 7/8"
    Ridge to Wall Length: 4 ft 3 3/16" (would this be the dims from the peak to the birdsmouth?)
  8. Jun 14, 2011 at 10:20 AM
    xJuice
    Josh
    North DFW
    07 DCSB Sport 2wd
    Someone feel free to correct me if I pooched the screw...
    p.s. Generally you make the seat cut of the birdsmouth as wide as the member it's sitting on, but the 3-1/2" here cuts into the rafter quite a bit so I cut it to 3" in my example. If you make the seat cut 3-1/2" the heel cut becomes 1-7/16" instead of 1-1/4".
  9. Jun 14, 2011 at 10:33 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    What is the width of your exterior wall framing ? 2x4 or 2x6 ?
  10. Jun 14, 2011 at 10:56 AM
    OZ-T
    Peter North
    British Columbia
    I'll assume you framed your exterior walls with 2x4 .
    Layout a 22.5 degree plumb cut at the top and cut it .
    Hook your tape onto the long point of the angle and measure down the top of the rafter 51 1/8 , draw another plumb line the same as the one on the top , this represents the exterior wall line .
    Continue measuring down the top of the rafter and make another plumb line at 59 3/4 , this is the total length of rafter including the 8" overhang .
    To cut the birdsmouth , draw a line square to your plumb line you marked representing the exterior wall , the level leg of the birdsmouth should be 3 1/2" . Do not over cut .
    I'll post a pic , hang on
  11. Jun 14, 2011 at 10:56 AM
    hendooman
    Jeff
    KC
    96" outside width with 2x4's.
    Thanks
  12. Jun 14, 2011 at 11:06 AM
    OZ-T
    Peter North
    British Columbia
    I'll check in here if you have some more questions
    Are you putting plywood on the frame ?
  13. Jun 14, 2011 at 11:13 AM
    97yota4wd
    Eric
    Mesa, AZ
    this shit is so confusing...
    *trying to learn for future referance..*
  14. Jun 14, 2011 at 11:14 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    X2, :popcorn: Learn something new everyday!
  15. Jun 14, 2011 at 11:15 AM
    hendooman
    Jeff
    KC
    You guys are a huge help. I am going to decipher all this info tonight after work and draw up some lines on a 2 x 4. I will shout back if I get stuck. Thanks again. This is a huge help.
  16. Jun 14, 2011 at 11:16 AM
    hendooman
    Jeff
    KC
    Yes plywood for the roof, tar paper then regular asphalt shingles.
  17. Jun 14, 2011 at 11:17 AM
    OZ-T
    Peter North
    British Columbia
    I meant the walls .
  18. Jun 14, 2011 at 11:18 AM
    hendooman
    Jeff
    KC
    I will use some cheap 4 x 8 siding more than likely...Menards usually has it for $15 a sheet or so. I am going to paint it the color of my house so I want it to be pretty decent stuff.
  19. Jun 14, 2011 at 11:22 AM
    97yota4wd
    Eric
    Mesa, AZ
    yeah some pretty useful info here
  20. Jun 14, 2011 at 11:26 AM
    OZ-T
    Peter North
    British Columbia
    You may want to over size the birdsmouth by the siding sheeting + a hair so that you don't need to notch around all the rafter tails .
    I can explain this if needed , but won't confuse the issue if you don't want to do that .
